You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 4.5.5 (2415) English
Goto Page: Previous1 2 3 4 5 6
#51 Re: PSPad unicode 4.5.5 (2415) English
Posted by: tyzio | Date: 2011-03-11 08:43 | IP: IP Logged
Exception:
1. Go to Highlighter settings->Compiler
2. In Log Parser type: *Line%S%L:*
3. Click Debug Button
4. In LOG test start writing: Line<space><space>
5. Window with Exceptions appears.
I sent you an email with exception Log.
#52 Re: PSPad unicode 4.5.5 (2415) English
Posted by: tionescu | Date: 2011-03-11 09:25 | IP: IP Logged
@former_poster: What issue/bug is this related to ?
Exception description:
Access violation at address 0in module 'PSPad.exe'. Read of address 0.
Exception address: 0
Stack list, generated 03/11/2011 11:24:11 AM
Thanks for the report,
but please do not post such lists to the forum,
rather send it to Jan by mail (see Help > About)
Thank you.
Спасибо за доклад,
но, пожалуйста, не пишите такие списки на форум,
а отправить его в Янв по почте (см. Справка> О программе)
Спасибо.
Díky za zprávu,
ale prosím neposílejte takové seznamy na fóru,
spíše zaslat jej na Jana poštou (viz Nápověda> O aplikaci)
Děkuju.
Program : C:\Tools\PSPad\PSPad.exe 4.5.5 (2415)
System : Windows XP Professional, Version: 5.1, Build: A28, "Service Pack 3"
Processor: Intel, Intel(R) Core(TM)2 Quad CPU Q9400 @ 2.66GHz, 2650 MHz MMX
Display : 1440x900 pixels, 32 bpp
Active Controls Hierarchy:
TEdit ""
TGroupBox ""
Edited 1 time(s). Last edit at 2014-07-14 18:06 by Stefan.
#53 Re: PSPad unicode 4.5.5 (2415) English
Posted by: pspad | Date: 2011-03-11 13:10 | IP: IP Logged
Fixed. Fix will be available in the next build
#54 Re: PSPad unicode 4.5.5 (2415) English
Posted by: pspad | Date: 2011-03-11 19:28 | IP: IP Logged
PGomersall:
Jan,
I have found a possible issue with the close\minimize to tray icon feature.
You open file A in folder B. You then close file A and "close" PSPad to tray icon - PSPad still has handle on folder B - you cannot delete folder B until you exit PSPad.
I hope this is not by design and that there is a work around?
Pete
Not yet, but next build will release working folder
#55 Re: PSPad unicode 4.5.5 (2415) English
Posted by: hankejh | Date: 2011-03-16 02:55 | IP: IP Logged
myf:
Eye-candy and text editor. Please, never ever mix those two things together. Nowadays there are terabytes and teraflops spent on handling gradient backgrounds that are in most cases useless, annoying and ugly. Do not participate, please.
Moreover, PSPad now works quite well with inverse system colour schemes. I am not sure it would be even possible to use gradient backgrounds in a way that will work in every colour environment.
I would be surprised if such small gradients painted per tab change amounted to any significant processor time whatsoever. And given the option to select the color of a tab allows a user to choose what they think looks good (that's the benefit of the highlighter color selections). So there's no reason to stick with ugly when elegant is an option (see the image in my post above -- which is certainly not* ugly).
All of this aside, however... the real issue I'm having is that selecting one of three or more colored (say green) tabs does not notably highlight the selected tab -- there is only a slight raised top to the selected tab (which is next-to-impossible to find -- and once found, it took too long).
Perhaps a bold font on the selected tab would solve this? That is more important than gradients, although gradients would be a slick option -- and a feature no one is being forced to use winking smiley
In any case, I think the colored tab implementation Jan pushed in the prior build is fantastic -- I just hope for more significant highlighting of a selected tab.
