You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.5 (2412) English
Goto Page: Previous1 2
#11 Re: PSPad unicode 4.5.5 (2412) English
Posted by: human | Date: 02/28/2011 08:59 | IP: IP Logged
Are you trying to hide PSPad with some external application?
In PSpad is a new functionality what allows you to minimize PSpad when you close it or exit it. It means catch this message.
See program settings / system / minimize on exit e.t.c.
Yes, I try to hide PSPad with external applications. There are different tools that use this function for implementing virtual desktops or moving windows to system tray. Is it possible that PSPad doesn't catch that message if it's switched of in settings or calls the "standard event" if it's disabled?
human
#12 Re: PSPad unicode 4.5.5 (2412) English
Posted by: TomasV | Date: 02/28/2011 12:59 | IP: IP Logged
TomasV:
Hi, with version 2411 newsgroup urls (news:xxxxxx@xxxxxx.xxx) are no longer clickable in text files. Could you have a look at it please? Or is there some TXT highlighter setting that I've missed?
Seems to be fixed in 2415, thanks!
#13 Re: PSPad unicode 4.5.5 (2412) English
Posted by: Marten | Date: 03/04/2011 17:28 | IP: IP Logged
Hi Jan,
I want to send you a zipfile with an example of a C++ project with most (I'm not sure of all) of the possibilities to test the code explorer.
How can I send it to you?
#14 Re: PSPad unicode 4.5.5 (2412) English
Posted by: vbr | Date: 03/04/2011 18:16 | IP: IP Logged
Marten:
Hi Jan,
If the size of the file allows it, I believe, you can send it to Jan using the e-mail address written in the Help menu: About dialog of PSPad.
Regards
#15 Re: PSPad unicode 4.5.5 (2412) English
Posted by: Marten | Date: 03/04/2011 18:35 | IP: IP Logged
Thanks. I'll send the example.
