You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.5 (2405) English
#41 Re: PSPad unicode 4.5.5 (2405) English
Posted by: mce | Date: 2010-12-20 18:55 | IP: IP Logged
Can something similar be implemented for clips, instead of pressing ctrl+space?
Thanks,
Cristian
#42 Re: PSPad unicode 4.5.5 (2405) English
Posted by: martovskiy | Date: 2010-12-22 14:44 | IP: IP Logged
Couldn't post bug into bugs forum.
1. create a new file
2. type 12345
3. Search/replace CTRL-H
check regular expressions
find 3
replace \n3
It's looks like pspad continue to search from next line, where found a 3 and insert another \n3 and so on.
#43 Re: PSPad unicode 4.5.5 (2405) English
Posted by: pspad | Date: 2010-12-22 16:10 | IP: IP Logged
martovskiy:
2. type 12345
find 3
replace \n3
Yes, you are right. But it will be hard to manage it.
You can use your replace from the end with (o)backward direction
#44 Re: PSPad unicode 4.5.5 (2405) English
Posted by: sandrosilveira | Date: 2010-12-22 17:31 | IP: IP Logged
Hi Jan,
Using the release 2405 I saw a small bug in code explorer for COBOL programs.
"w-other-var" at line 19 and "end-if" at line 24 are shown as paragraphs, but they are respectively a variable and a reserved word.
(click the Quote link for this post to get the right indentation of the sample program):
identification division.
program-id. test.
environment division.
configuration section.
special-names.
decimal-point is comma.
data division.
working-storage section.
01 wrk-vars.
05 w-var pic is x(10).
05 w-other-var pic is x(10).
procedure division.
start-of-program.
move "aa" to w-var.
display w-var,
w-other-var.
test-paragraph.
if w-var = spaces
display "some text",
end-if.
end-of-program.
stop run.
#45 Re: PSPad unicode 4.5.5 (2405) English
Posted by: pspad | Date: 2010-12-22 17:59 | IP: IP Logged
I tested it and don't see any problem.
Can you attach screenshot and mark what is wrongly highlighted?
#46 Re: PSPad unicode 4.5.5 (2405) English
Posted by: human | Date: 2010-12-23 07:59 | IP: IP Logged
I cannot reproduce the issues mentioned in #44.
Speaking of COBOL, the bugs mentioned in forum.pspad.com (#34 - #37) are still there.
human
#47 Re: PSPad unicode 4.5.5 (2405) English
Posted by: pspad | Date: 2010-12-23 08:58 | IP: IP Logged
human:
human
Done. Modifications will be available in the next build
#48 Re: PSPad unicode 4.5.5 (2405) English
Posted by: sandrosilveira | Date: 2010-12-23 12:00 | IP: IP Logged
Hi Jan.
Screenshot for wrong COBOL code explorer marked with red ellipses: www.rech.com.br
#49 Re: PSPad unicode 4.5.5 (2405) English
Posted by: pspad | Date: 2010-12-23 13:40 | IP: IP Logged
I am sorry. I missed you wrote about Code explorer. I looked for problems in highlighting
#50 Re: PSPad unicode 4.5.5 (2405) English
Posted by: human | Date: 2011-01-04 13:46 | IP: IP Logged
Another COBOL problem:
Using Format->Add/Remove Comment sets * in column 1, not in column 7
human
