You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.5 (2405) English
Posted by: pspad | Date: 12/15/2010 06:18 | IP: IP Logged
crimson:Hi Jan:There is a minor bug. After I updated to 2405, the the script items show twice in the submenu of Scripts menu. Please check it. Thx a lot.
best regards.
crimson
Can anybody confirm it?
Posted by: carbonize | Date: 12/15/2010 09:22 | IP: IP Logged
pspad:crimson:Hi Jan:There is a minor bug. After I updated to 2405, the the script items show twice in the submenu of Scripts menu. Please check it. Thx a lot.
best regards.
crimsonCan anybody confirm it?
To be honest I've been seeing this behaviour for a couple of builds now.
Carbonize
Posted by: stefangabos | Date: 12/15/2010 09:56 | IP: IP Logged
myf:stefangabos:pspad:stefangabos:A small bug that it has been persisting for a while: if I select a *single* line and press CTRL-H (Replace) the "Scope" it's set to "Global" rather than "Selected text".This is behavior by design, not a bug. And user wish.
Find more users who will want to change it and I will change it or make it optional.but it does not have any sense. if i have selected text than I expect the replace to refer to the selected text...
Would you like to have 'Selection only' preselected by default even if your selection contains a single word? Or even a single character?
Dunno how much 'hardcore' I am, but I quite appreciate current behaviour: if my selection does not overlap a line scope, replace is 'Global' by default. This fits the case you are writing about: selection is form the start of line to its end, and no further. I usually select a line by {2×home}{shift+down} keystroke sequence (and, CMIIW, there is no built-in action for 'select line' operation in PSPad). In this case selection contains line-break and thus 'Selection only' is preselected, what typically fits exactly my needs. You may try to do it this way too, maybe you'll like it.
thanks, that indeed works. the way I do it is {2xhome}{shift+end} and this way is not working
So, I still consider it to be a very small bug. I'll just adjust my behaviour. thanks a lot for taking the time to write!
Posted by: chuckf | Date: 12/15/2010 18:29 | IP: IP Logged
pspad:News
Search/Replace - PSPad will keep position when nothing is found
Search file from log priority change - PSpad search in compiler folder first, then in project and open files
File detection mechanism was rewriten
Hi Jan,
Thanks for the update.
Thanks for making the change to the Search/Replace.
The Search file from log priority change, however, does not work for me. It still finds a different file. Could it be that the file path has forward slashes in it? I doubt it since the LOG parser looks correct...
My error message looks like:
ssh/openssh/log.c:69: error: expected blah, blah, blah
The LOG paser debugger show Results:
File name (%F): ssh\openssh\log.c
Line(%L): 69
as expected.
My Compiler default directory is:
l:\work\nnssht\ssh
and I can find the file at:
l:\work\nnssht\ssh\ssh\openssh\log.c
Is there anything I can do here?
Thanks again,
chuckf
Posted by: pspad | Date: 12/15/2010 19:41 | IP: IP Logged
Are there really two ssh folders?
Posted by: MadCompie | Date: 12/15/2010 20:28 | IP: IP Logged
The 2405 build didn't solve the external file change detection
example: open a text file in pspad
open the same file in notepad
do some changes in notepad + save
go to pspad: there is no longer a message that the file has been changed?
sometimes it works but mostly not...
in previous versions there was no problem
Posted by: pspad | Date: 12/15/2010 21:33 | IP: IP Logged
MadCompie:The 2405 build didn't solve the external file change detection
Check this build:
forum.pspad.com
Posted by: MrSpock | Date: 12/15/2010 23:50 | IP: IP Logged
crimson:After I updated to 2405, the the script items show twice in the submenu of Scripts menu.
Cannot confirm this on Win XP SP3.
Posted by: chuckf | Date: 12/16/2010 17:36 | IP: IP Logged
pspad:Are there really two ssh folders?
Yes, there are.
L:\work\nnssht\ssh\ssh\openssh>dir log.c
Volume in drive L is chuckf
Volume Serial Number is 20D5-080F
Directory of L:\work\nnssht\ssh\ssh\openssh
12/15/2010 11:32 AM 9,444 log.c
1 File(s) 9,444 bytes
0 Dir(s) 58,554,114,048 bytes free
Posted by: kiendlm | Date: 12/16/2010 22:01 | IP: IP Logged
best regards.
crimson
Cannot confirm this on Win 7 x64.
