You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.5 (2390) English
Goto Page: Previous1 2 3 Next
#11 Re: PSPad unicode 4.5.5 (2390) English
Posted by: holger | Date: 2010-06-01 11:42 | IP: IP Logged
First of all:
Thanks for the new Version with all these Bugfixes!
First I looked up for the new Parameter "CheckDeleted=0", which wasn't there!
Then after verifying the Settings by pressing OK, the refresh of filecontent (when activate PSPad) did not working anymore.
The Question for refresh was not appearing.
Restart of PSPad didn't change anything.
After set & unset autorefresh for a file everything is OK, the Parameter "CheckDeleted=0" was added.
May this be useful for other Users to remember checking/creating this option (manually or on this Way).
#12 Re: PSPad unicode 4.5.5 (2390) English
Posted by: pspad | Date: 2010-06-01 12:34 | IP: IP Logged
Parametr se vytvori úpri prvnim ulozeni parametru programu.
Jako vychozi je detekce vypnuta, takze nebude obtezovat.
#13 Re: PSPad unicode 4.5.5 (2390) English
Posted by: nielsd | Date: 2010-06-01 14:08 | IP: IP Logged
Thanks for the update of the AutoMod code explorer!
Unfortunately I cannot make it work. I have tried the release where the new AutoMod stuff was added (2388) and this one (2390).
I simply unpack the files and copy them into my PSPad dir under Program Files, and then restart PSPad. What (if anything) am I doing wrong?
Kind Regards,
Niels Døssing
#14 Re: PSPad unicode 4.5.5 (2390) English
Posted by: smoon177 | Date: 2010-06-02 03:27 | IP: IP Logged
Yes, now I give you some example. Below lines is after format code and the dots represent the arising spaces.
<div class="body_site">.............................<h2>Đăng tin hỏi đáp</h2>
and here
<tr>.........................<td>Content</td>.......................<td>Content</td>
and here
<p>Text</p>.........................<br clear="all">
#15 Re: PSPad unicode 4.5.5 (2390) English
Posted by: holger | Date: 2010-06-02 07:01 | IP: IP Logged
Oups, I have to correct my post:
After some actions (don't know which), I get the behavior (Refresh don't work) again, without Changing any Settings.
Then try to validate the Settings by pressing OK Button is changing nothing.
Only set/reset the Autorefresh for a File seems to set to normal expected behavior..
Please Proof.
Thanks in Advance.
#16 Re: PSPad unicode 4.5.5 (2390) English
Posted by: stefangabos | Date: 2010-06-02 10:11 | IP: IP Logged
Select a portion of text. Now click ctrl-h (Replace). The "Scope" should be set to "Selected text" (as there is a portion of text selected) but it is set to "Global".
#17 Re: PSPad unicode 4.5.5 (2390) English
Posted by: Anonymous User | Date: 2010-06-02 10:23 | IP: IP Logged
For me this is the situation when selecting a single line only. Works correctly when selecting multiple lines.
#18 Re: PSPad unicode 4.5.5 (2390) English
Posted by: stefangabos | Date: 2010-06-02 10:56 | IP: IP Logged
Indeed, it happens only when selecting a single line of text. Thanks for pointing that out!
#19 Re: PSPad unicode 4.5.5 (2390) English
Posted by: jbyrne | Date: 2010-06-03 03:53 | IP: IP Logged
c3k:
Fixes
file change detection using GetFileInformationByHandle()
Just tested new version, still can't get the expected results... :(
Have you try my test in this post:
www.youtube.com
forum.pspad.com
File change detection now not working under Windows 7
#20 Re: PSPad unicode 4.5.5 (2390) English
Posted by: nielsd | Date: 2010-06-03 06:30 | IP: IP Logged
Please ignore my post (#13)!
For some reason I had two PSPad installations (one in C:\Programs Files\ and one in C:\Programs\), and at a glance I didn't realize that my shortcut was pointing into the opposite one to where I made the update tongue sticking out smiley
So now it is working smiling smiley
/Niels
