You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.5 (2388) English
Posted by: pspad | Date: 2010-05-20 18:32 | IP: IP Logged
Download links (2.1 MB):
pspad.cincura.net
pspad.siliconhill.cz
Changes to 4.5.5 (2386)
News
TextDiff is scrolling with window above
Code explorer for AutoMod (ftAUM) was extended
Code explorer for CSS shows used colors
Cobol highlighter - words pair highlighting
Color select - dblclick on stored color adds color into editor
Color translator - stored colors was added
Code explorer for UnIcon
New command line parameter -N or /N runs new PSPad instance
Fixes
JScript comment
Drag/Drop from internal file explorer into HEX editor and TextDiff
Statusbar supports unicode chars
Statusbar - char update after delete char
Statusbar - cursor position shows number of char before cursor
Project synchronization wasn't available is no file was open
CSS highlighter - highlight of the matching bracked fix
Project doesn't store extensions for synchronization
Posted by: Nelson | Date: 2010-05-21 02:02 | IP: IP Logged
pspad:Fixes
I think the statusbar area width should be bigger, thus it can display Unicode chars better.
Some chars (such as Chinese chars) are double char, they need more spaces to display.
Posted by: pspad | Date: 2010-05-21 05:01 | IP: IP Logged
OK. I wanted to increase yesterday, but I forgot it
Posted by: fpana78 | Date: 2010-12-14 10:48 | IP: IP Logged
The new autocomplete function is quite slow... how I can disable it?
Posted by: vbr | Date: 2010-12-14 12:41 | IP: IP Logged
fpana78:The new autocomplete function is quite slow... how I can disable it?
You can do that by setting the delay to 0:
Settings: Editor (part 2): Autocomplete delay [ms]: [ 0 ]
[this functionality is available from the build 2401 above; not in 2388 from this thread]
