You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.5 (2386) English
Posted by: Laisvunas | Date: 2010-04-04 18:22 | IP: IP Logged
Hi Jan,
It seemed like a bug and it turns out to be a feature!
Thanks for explanation.
Posted by: cebe | Date: 2010-04-12 14:51 | IP: IP Logged
lots of problem when tring to edit (on HTML multihighlighter mode) a long single line text with "lines wrapping" option to on.
Sorry, but "mail log" doesn't work.
Here is the trace :
Exception class:
Exception address:
Stack list, generated 12/04/2010 16:45:28
Deleted.
Please send such logs to the e-mail address found in PSPad help menu.
Thanks
the mod
Program : C:\Program Files\PSPad editor\PSPad.exe 4.5.5 (2386)
System : Windows XP Professional, Version: 5.1, Build: A28, "Service Pack 3"
Processor: AMD, AMD Athlon(tm) Dual Core Processor 4850e, 2520 MHz MMX
Display : 1920x1200 pixels, 32 bpp
Active Controls Hierarchy:
TPSSynEdit "Editor1"
TfChildEdit "fChildEdit_5"
Edited 1 time(s). Last edit at 2010-04-25 13:55 by Stefan.
Posted by: TheBrawnyMan | Date: 2010-04-14 22:11 | IP: IP Logged
Thank you for all your hard work. I found a possible bug in versions 4.5.4 and development build 4.5.5 (2386). When working on a local file, if you open an FTP connection and then save that local file to ftp (Shift+Ctrl+S) PSPad treats that file like a file that was originally opened via FTP changing the path of the file in the title bar to the ftp path, adds the remote file symbol to the file's tab, etc. saving the file using the normal save (Ctrl+S) appears to save to both local and remote. When closing and reopening PSPad any files in the previous session that were saved to ftp are not automatically re-opend.
Posted by: carbonize | Date: 2010-04-16 10:11 | IP: IP Logged
You need to clarify which behaviour you believe to be the bug. Treating the file as remote once you save to FTP makes sense and was requested.
Carbonize
Posted by: TheBrawnyMan | Date: 2010-04-16 17:58 | IP: IP Logged
I guess to me the treating the file as a remote file was the bug. I didn't see this requested so if its now a feature. Assuming that saving does in fact save to the server and locally then its not a big deal. To me personally, it disrupts my work flow (particularly the part where the files don't re-open on launch). If its possible to make this behavior an option in Program Settings than that would be ideal.
Posted by: holger | Date: 2010-04-20 11:38 | IP: IP Logged
How to avoid this message?
Warnung
File content change check - file not found! Deleted?
D:\proALPHA\LDemo\Temp\EchtData\sdproto.d
OK
I don't need that, because most times I know what I have been done...
If then I try to open another file (mostly per other App or Drag&Drop), this message blocks PsPad and it don't open that File.
Better for me:
Delete the Tabs of deleted files automatically.
Please help!
Edited 1 time(s). Last edit at 2010-04-20 11:40 by holger.
Posted by: holger | Date: 2010-04-22 13:14 | IP: IP Logged
Also Sorry, but I don't want to use Maillog in my Company
Exception description:
I tried out the newly function to refresh a project:
1. Created with "Create Project from Dir..." (W:\)
Syncronize Files with: *.p,*.w,*.lib,*.i,*.if (Works!)
3. Save as W:\testProject.ppr
4. name that Folder which kept empty
5. Save
6. Syncronize with Drive Content (In the Projectexplorer the Name and the Rootfolder are empty again).
7. Save
8. Open the project raise the Exception.
9. After deleting Content of [Project tree]
from projectfile with Notepad, everything is empty, File-Filter is deleted in Settings, Projectexplorer is emtpy.
Invalid index.
Exception class:
Exception address:
Stack list, generated 22.04.2010 14:47:16
Deleted.
Thanks
the mod
Program : C:\Programme\PSPad editor\PSPad.exe 4.5.5 (2386)
Processor: Intel, Intel(R) Core(TM)2 CPU 6400 @ 2.13GHz, 2120 MHz MMX
TfPSPad "fPSPad"
Edited 1 time(s). Last edit at 2010-04-25 13:57 by Stefan.
Posted by: holger | Date: 2010-04-23 10:44 | IP: IP Logged
OK, one more thing:
the Fileextensionfilter seems not to be saved with the Project.
It should be anywhere in the Projectfile, because once I defined it, the Synronizing with Filesystemcontent should know this, without choosing this again.
For help thanks in advance.
Posted by: mgutt | Date: 2010-04-24 18:01 | IP: IP Logged
is there an option to force displaying invisible files? If not please add it. ;)
regards
Posted by: pspad | Date: 2010-04-24 18:12 | IP: IP Logged
What is "invisible" file?
