You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.5 (2385) English
Goto Page: Previous1 2
#11 Re: PSPad unicode 4.5.5 (2385) English
Posted by: pspad | Date: 2010-03-08 18:07 | IP: IP Logged
c3k:
I've see nothing in the changelog, but something has changed...
please confirm
on my experience seems to work if you drag the file on the executable (i think is the same to doubleclick on it if associated)
but it don't if you use other method (drag and drop, open dialog, internal file manager) to open the file
is there a different behavior?
File check is back. File check doesn't depends of open file method.
#12 Re: PSPad unicode 4.5.5 (2385) English
Posted by: c3k | Date: 2010-03-10 10:07 | IP: IP Logged
i've just make a test:
www.youtube.com
Edited 1 time(s). Last edit at 2010-03-10 10:07 by c3k.
#13 Re: PSPad unicode 4.5.5 (2385) English
Posted by: pspad | Date: 2010-03-10 16:44 | IP: IP Logged
OK, I believe you even I don't understand yet. smiling smiley
#14 Re: PSPad unicode 4.5.5 (2385) English
Posted by: carbonize | Date: 2010-03-11 08:38 | IP: IP Logged
From what he is showing in the video he is saying that if you open a file by dragging it directly on to the executable or it's icon then PSPad detects file changes but if you open the file using the open dialogue, dragging the file on to the open PSPad window etc then file changes are not being detected.
Carbonize
#15 Re: PSPad unicode 4.5.5 (2385) English
Posted by: pspad | Date: 2010-03-14 10:25 | IP: IP Logged
I understood, whats happend, but I don't undestand, why PSpad has different behavior. It uses internally same method to open file winking smiley
#16 Re: JavaScript highlighter bug
Posted by: Vany | Date: 2010-03-24 20:16 | IP: IP Logged
but
<?php echo '?'.'>'; $not_highlighted = true; ?>
does the same job, but highlighter recognizes it wellwinking smiley
