You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.5 (2385) English
Goto Page: 1 2 Next
#1 PSPad unicode 4.5.5 (2385) English
Posted by: pspad | Date: 2010-02-26 16:47 | IP: IP Logged
Download links (2.1 MB):
pspad.cincura.net
pspad.siliconhill.cz
Changes to 4.5.5 (2384)
News
libraries update: JCL, TextDiff
Project synchronize uses ignore masks list (Program settings / Files) for folders too
Code format function remebers settings for individual highlighters between sessions
Fixes
Fixed ECHO highlighting for MSDos BAT highlighter
Perl highlighter - string \# was highlighted as comment
Fixed save ANSI file on VirtualBox shared folder
#2 Re: PSPad unicode 4.5.5 (2385) English
Posted by: sholle | Date: 2010-02-26 19:54 | IP: IP Logged
Just installed this version and my project tree is all screwed up. The order of the folders has changed and some folders are missing.
#3 Re: PSPad unicode 4.5.5 (2385) English
Posted by: pspad | Date: 2010-02-26 20:06 | IP: IP Logged
If you don't run project synchronization, PSpad doesn't do nothing with your project.
If some folder are missing, it means your folders are ignored, coz Program settings / Files contains ignore masks.
#4 JavaScript highlighter bug
Posted by: fetis | Date: 2010-02-27 19:39 | IP: IP Logged
fs.replace (/.*\//g, "");
treats "//" as a start of comment
this's not exactly 2385 bug, I saw this in 2383 too
I use PSPad for HTML, JS editing.
#5 Re: JavaScript highlighter bug
Posted by: pspad | Date: 2010-02-28 15:46 | IP: IP Logged
fetis:
Found and fixed. Wait for the next build
#6 Re: JavaScript highlighter bug
Posted by: fetis | Date: 2010-02-28 21:47 | IP: IP Logged
thanks
#7 Re: JavaScript highlighter bug
Posted by: erema | Date: 2010-03-01 11:03 | IP: IP Logged
<?php echo '?>'; $not_highlighted = true; ?>
PHP highlighter shows it correctly, but XHTML multihighlighter doesn't.
#8 Re: JavaScript highlighter bug
Posted by: BloodSword | Date: 2010-03-01 16:50 | IP: IP Logged
Is it possible to use the XHTML Highlighter for any custom higlighter slot as seconds highlighter?
I would like to see smarty highlighting with compatible HTML highlighting. smiling smiley
#9 Re: JavaScript highlighter bug
Posted by: carbonize | Date: 2010-03-01 18:07 | IP: IP Logged
erema:
This is a known bug in the editor component and has been reported many many many many many many times in the forum.
Carbonize
#10 Re: PSPad unicode 4.5.5 (2385) English
Posted by: c3k | Date: 2010-03-08 14:21 | IP: IP Logged
about file change check you say:
I will return it back
I've see nothing in the changelog, but something has changed...
please confirm
on my experience seems to work if you drag the file on the executable (i think is the same to doubleclick on it if associated)
but it don't if you use other method (drag and drop, open dialog, internal file manager) to open the file
is there a different behavior?
Goto Page: 1 2 Next
