You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.5 (2384) English
Posted by: pspad | Date: 2010-02-21 18:00 | IP: IP Logged
Download links (2.1 MB):
pspad.cincura.net
pspad.siliconhill.cz
Changes to 4.5.5 (2383)
News
Project from folder dialog
New multiline comment style for PowerShell <#..#> in User highlighter definition
Wordstar Layout support for editor shortcuts (you can define it)
Fixes
Open file from internet - problem in case of UTF-8 page encoding
File change detection
Edited 2 time(s). Last edit at 2010-04-03 06:16 by pspad.
Posted by: F170 | Date: 2010-02-21 21:32 | IP: IP Logged
Yeah! :D
Posted by: c3k | Date: 2010-02-21 21:46 | IP: IP Logged
Again: still not check file changes correctly when the main window get the focus.
WARNING: not usable with network files that could get open by other user o with log file that changes in real time.
If you need a minimal check for changes stop at ver 2357.
Posted by: pspad | Date: 2010-02-22 04:38 | IP: IP Logged
c3k:Again: still not check file changes correctly when the main window get the focus.WARNING: not usable with network files that could get open by other user o with log file that changes in real time.
There are about 2s, where PSPad doesn't detect it.
There was a problem with Windows 7 file change detection made by (in my opinion) version history.
I don't agree, that is unusable!
You are editing LOG files what are changed in realtime? What you editing on such files?
PSPad offers you autorefresh for logs, if you want to see results in realtime.
Posted by: c3k | Date: 2010-02-22 10:17 | IP: IP Logged
I've wait for much more than 2 seconds (on XP, Vista and 7), it seems I have to wait some minutes before MADE a changes, if I change before this interval it will be NEVER catched. It seems only one of the two windows (the same) is able to get the change. I've done many tests but seems a very random behavior, I've not found a way that make it always works...
I don't edit log files, but sometimes I've got one open with pspad
My big problem is with network file...if someone else open it while i'm editing i'll never, never know...
If the change is made for 7 (and it's not working on it too), could you turn back to the old behavior that was perfect on xp and vista?
Posted by: pspad | Date: 2010-02-22 10:49 | IP: IP Logged
I will return it back
Posted by: c3k | Date: 2010-02-22 13:38 | IP: IP Logged
pspad:I will return it back
thank you!
Posted by: Lolo | Date: 2010-02-23 08:33 | IP: IP Logged
c3k:WARNING: not usable with network files that could get open by other user o with log file that changes in real time.
I can confirm this behavior.
I have the same problem.
I hope it could be fixed in the next build.
Thanks for your hard work.
Posted by: crimson | Date: 2010-02-24 03:41 | IP: IP Logged
Thank you.
Posted by: crimson | Date: 2010-02-25 02:28 | IP: IP Logged
I can't see KeyMap.ini setting in [Setting]->[Program Setting]->[Key Map]. Does anybody see the same issue?
