You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.5 (2383) English
Goto Page: 1 2 3 4 5 Next
#1 PSPad unicode 4.5.5 (2383) English
Posted by: pspad | Date: 2010-02-01 05:39 | IP: IP Logged
Download links (2.1 MB):
pspad.cincura.net
Changes to 4.5.5 (2381)
News
new Project synchronization with disk include file extensions specification in Project settings. It's first version, modification of Project from folder dialog will follow
variable OldWhitespaceChar is back in program settings / Direct edit
XProfan 11 - new user highlighter from Stephan Sonneborn
Falcon 11 - new user highlighter from GRAWeeLD
possibility to sort file tabs alphabetically - menu Windows or file tabs context menu
Fixes
for new file extension TXT is set when Highlighter is switched off in Syntax change dialog
corrected exception after paste text into incremental search
fixed new comment style for C++ highlighter
fixed undo problems with active Autoindent mode
Edited 1 time(s). Last edit at 2010-02-01 08:15 by pspad.
#2 Re: PSPad unicode 4.5.5 (2383) English
Posted by: stefangabos | Date: 2010-02-01 08:33 | IP: IP Logged
pleeeeease fix the autoindent feature - it used to work in previous versions and now, for about 3 versions is broken: i want the indentation to be remembered for more than a single row. my coding style is so that i leave a blank line after every line and so when i get to the line i want to write in, the cursor forgets indentation.
thank you!
#3 Re: PSPad unicode 4.5.5 (2383) English
Posted by: pspad | Date: 2010-02-01 08:51 | IP: IP Logged
Write me step by step how to get broken autoindent undo
I try undo and for me it seems to be OK
I try pro press several times Enter and it keeps autoindented
Edited 1 time(s). Last edit at 2010-02-01 08:52 by pspad.
#4 Re: PSPad unicode 4.5.5 (2383) English
Posted by: stefangabos | Date: 2010-02-01 09:07 | IP: IP Logged
here's an image:
#5 Re: PSPad unicode 4.5.5 (2383) English
Posted by: pspad | Date: 2010-02-01 09:17 | IP: IP Logged
You have active Trim Trailing spaces option. Switch it off.
#6 Re: PSPad unicode 4.5.5 (2383) English
Posted by: stefangabos | Date: 2010-02-01 09:35 | IP: IP Logged
Thanks! It works now. But I'd still want PsPad to "Trim trailing spaces" once I save the file. Is that possible?
Anyways, thanks a lot for your quick answer!
#7 Re: PSPad unicode 4.5.5 (2383) English
Posted by: MrSpock | Date: 2010-02-01 17:25 | IP: IP Logged
Thanks for the new build.
One of the new strings in the language files is apparently not applied or saved correctly. Using the latest English.INI:
#8 Re: PSPad unicode 4.5.5 (2383) English
Posted by: pspad | Date: 2010-02-01 19:07 | IP: IP Logged
MrSpock:
Thank you.
#9 Re: PSPad unicode 4.5.5 (2383) English
Posted by: crimson | Date: 2010-02-02 03:35 | IP: IP Logged
Thank you for the new build to enhance project sync feature. It's really usable to me. tongue sticking out smiley
#10 Re: PSPad unicode 4.5.5 (2383) English
Posted by: crimson | Date: 2010-02-02 04:50 | IP: IP Logged
crimson:
The link is not reachable for me. Please help to check. Thx.
