You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 4.5.5 (2381) English
Goto Page: Previous1 2 3
#21 Re: PSPad unicode 4.5.5 (2381) English
Posted by: bobbydj | Date: 2010-01-26 09:04 | IP: IP Logged
When you open PsPad, he remembers the last open sources and opens them.
But he does not remember the tags.
Can you add it?
Thanks in advance.
#22 Re: PSPad unicode 4.5.5 (2381) English
Posted by: bovirus | Date: 2010-01-31 10:14 | IP: IP Logged
I found some problems about view text file with build 2381 (works fine with 2374).
I open this file with Notepad or PsPad 2374
---------------------------------------------------------- UT-Starcom UT-300R2U 1. serie (PSPBOOT)
Board identificata come DSL699E V. 7.5G REV: 1.0 050601
CPU: TI AR7 TNED7300AGDW
FLASH (2MB) : MX29LV160BBTC-70
RAM (8MB): APEX AT364164T-7
This is that you can view.
If you open the same text file with Pspad 2381 the result is different.
I cannot use copy & paste because the result is correct. Just only view is wrong.
there are some space with the characters.
But when you edit the etxt file what you see is not what you are editing.
#23 Re: PSPad unicode 4.5.5 (2381) English
Posted by: pspad | Date: 2010-01-31 10:52 | IP: IP Logged
bovirus:
Switch off view of special chars (menu view or toolbar button)
#24 Re: PSPad unicode 4.5.5 (2381) English
Posted by: pspad | Date: 2010-02-01 13:51 | IP: IP Logged
bobbydj:
Can you add it?
Thanks in advance.
What you mean? I don't understand what tag should PSpad remember.
#25 Re: PSPad unicode 4.5.5 (2381) English
Posted by: bobbydj | Date: 2010-02-01 15:06 | IP: IP Logged
bobbydj:
Can you add it?
Thanks in advance.
Sorry, I meant Bookmark created via Alt+Left.
#26 Re: PSPad unicode 4.5.5 (2381) English
Posted by: pspad | Date: 2010-02-01 15:27 | IP: IP Logged
About up to 20 bookmarks is stored too, if you enable
[x]Save file state in Program settings / Files and dirs
or if you are using projects
#27 Re: PSPad unicode 4.5.5 (2381) English
Posted by: karminski | Date: 2010-04-02 05:17 | IP: IP Logged
RickH:
This may be a more extension-specific issue, but this build seems to have broken (at least) the any_tag_close extension.
Instead of placing the close tag at the cursor, it's placed at the beginning of the line. Possibly the cursor position isn't being properly read.
In this case, you can get the extension working again by uncommenting line 105, although the page then scrolls, which might be why this line was commented out.
Has same issue! Please fix it! It's very powerfull extension saving a lot of coding time!
1C-Bitrix: web-site logic and interface developer
