You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.5 (2370) English
Goto Page: 1 2 3 4 Next
#1 PSPad unicode 4.5.5 (2370) English
Posted by: pspad | Date: 09/27/2009 21:58 | IP: IP Logged
Download links (2.1 MB):
pspad.cincura.net
pspad.siliconhill.cz
Changes to 4.5.4 (2357)
News
FTP client - '..' is available always
HTML preview - refresh after file save
Progress code explorer - added Temp table structure support
ABB rapid Code explorer - addedd Traps support
Updated JCL library - processor and OS detection e.t.c.
Progress highlighter - addedd new keywords
Programm remembers Code clips window size during sessions
Remove file from project (Shift+Ctrl+Del) is available only if project Window is focused
Corrections
Open files from internet history wasn't stored
Hanlded exception is file was closed on background
FTP client - movement using arrows
Switch to HEX when whole text was selected and file type was different from DOS
Open Text files from project with double click
File change detection
FTP - random command can't be switched off
#2 Re: PSPad unicode 4.5.5 (2370) English
Posted by: naputtelija | Date: 09/28/2009 12:32 | IP: IP Logged
Auto indent mode does not work in this build. I reverted back to 2357 because auto indent is so important feature.
#3 Re: PSPad unicode 4.5.5 (2370) English
Posted by: ferry | Date: 09/28/2009 12:50 | IP: IP Logged
a) Highlight Matching Brackets does not work in this build. I reverted back to 2357.
b) Is it possible to refresh Code Explorer from a keyboard (not only from an icon, with the mouse)? (or, better, anytime Code Explorer is accesed. Maybe, as an option in setup).
#4 Re: PSPad unicode 4.5.5 (2370) English
Posted by: pspad | Date: 09/28/2009 13:31 | IP: IP Logged
ferry:
Highlight matching brackets for what language? I check it, but I can miss some highlighter.
#5 Re: PSPad unicode 4.5.5 (2370) English
Posted by: pspad | Date: 09/28/2009 13:35 | IP: IP Logged
naputtelija:
I can't confirm, autoindent mode - new line starts in same position as previous line - works OK.
#6 Re: PSPad unicode 4.5.5 (2370) English
Posted by: naputtelija | Date: 09/28/2009 14:34 | IP: IP Logged
I tested this more and I found that indent behaviour depends on setting "Scroll past EOL and EOF". If selected, then auto indent works. If unselected, indentation does not work.
#7 Re: PSPad unicode 4.5.5 (2370) English
Posted by: pspad | Date: 09/28/2009 15:57 | IP: IP Logged
naputtelija:
Thank you for the advice. It's really strange.
#8 Re: PSPad unicode 4.5.5 (2370) English
Posted by: wascallywabbit | Date: 09/28/2009 17:56 | IP: IP Logged
I have been using 4.5.4 for a while now because every time I try to use 4.5.5 it doesn't remember the window position. I am using the settings I used on 4.5.4. Now, regardless of setting save window position, it always loads on monitor1 instead of monitor2 which is where I want it. Am I missing something different between the two versions?
Thanks
#9 Re: PSPad unicode 4.5.5 (2370) English - Problems confirmed.
Posted by: BloodSword | Date: 09/29/2009 11:44 | IP: IP Logged
I tested the problems and I can confirm and reproduce them:
- Textfiles are opened in PSPad again wen doubleclicked from the project tree. Fine smiling smiley
- Autoindent problem confirmed. If Scroll past EOL is active, then it works BUT if I delete the indent, it goes char by char, not automalicy. And it is annoying that the curser goes after the end of line.
- On PHP highlighting brackets works well.
- On JavaScript, too
- And on XHTML Multihighlighter.
Will revert to previous build, waiting for the next.
PS: The audoindent works well on previous built, but I noticed some change when Scolling past EOL is active:
The deletion of the indent goes char by char and if Scrolling past EOL is inactive, it goes rapidly away.
That's really odd...
#10 Re: PSPad unicode 4.5.5 (2370) English
Posted by: ferry | Date: 09/30/2009 20:09 | IP: IP Logged
Highlighter C/C++
a) I test it again three times. Unzipping "pspad455b2370.cab" on directory "C:\Program Files\Pspad editor" Highlight Matching Brackets does not work. Unzipping "pspad455b2357.cab" on same directory, Highlight Matching Brackets works fine as always.
b) Now every time I use the Code Explorer, I must click the mouse two times, first on the icon "Refresh" and second on the function name.
Is it possible an icon like "Set focus to source" called "Auto Refresh", which do the "refresh" action same time I click on a function name?
Thanks for PsPad. I use it since 2003.
