You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 4.5.5 (2357) English
Posted by: twooton | Date: 2009-09-24 20:02 | IP: IP Logged
For the syntax highlighting, when you have special chars on so you can see tabs and spaces, the color of the spaces/tabs takes on the color of the previously highlighted code on that line. Spaces/tabs on new lines look fine. (I like to have the spaces/tabs a very light grey so I can see what they are but they don't bug my eyes)
Posted by: MrSpock | Date: 2009-09-24 20:34 | IP: IP Logged
twooton:I like to have the spaces/tabs a very light grey so I can see what they are but they don't bug my eyes
I would prefer that too, but apparently it's more difficult than it looks. (I remember a forum conversation a while ago.)
Posted by: twooton | Date: 2009-09-24 21:47 | IP: IP Logged
MrSpock:twooton:I like to have the spaces/tabs a very light grey so I can see what they are but they don't bug my eyesI would prefer that too, but apparently it's more difficult than it looks. (I remember a forum conversation a while ago.)
I was afraid of that. I'd rather it work as fast as it does than slow down because its trying to account for whitespace in the syntax highlighting. But if the process is cheap, why not
Posted by: wegiera | Date: 2009-09-25 08:40 | IP: IP Logged
May I kindly request You for two improvements in PsPad?
1) Placing HTML internal viewer as one of PsPad tab pages
2) Adding "can't place cursor after the end of line" into program settings
Zdrufko
Andrzej Wegierski
Posted by: vbr | Date: 2009-09-25 18:11 | IP: IP Logged
wegiera:2) Adding "can't place cursor after the end of line" into program settings
Try Settings: Editor 1: [ ] Scroll past EOL and EOF
or did you mean, that the two options should be separated?
Posted by: sholle | Date: 2009-09-25 20:45 | IP: IP Logged
I think I found my problem with the ftp in this version. I connect to a VMS box and the ftp command LIST is invalid. I cannot get the random command to uncheck and stick. Whenever the random command comes to LIST pspad hangs until timeout. I think all I need id for the random command to uncheck.
Posted by: pspad | Date: 2009-09-26 02:38 | IP: IP Logged
sholle:I think I found my problem with the ftp in this version. I connect to a VMS box and the ftp command LIST is invalid. I cannot get the random command to uncheck and stick. Whenever the random command comes to LIST pspad hangs until timeout. I think all I need id for the random command to uncheck.
If List command make s problem, I will remove it from list. It's specific command, coz it need to recieve file list from server, not only send it.
There was bug in random option. You can temporary switch off keep connection alive option
Posted by: Tadeu | Date: 2010-01-21 12:02 | IP: IP Logged
Bump! Me too!
