You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.4 (2353) English
Posted by: pspad | Date: 2009-07-05 14:44 | IP: IP Logged
Download links (2.1 MB):
pspad.cincura.net
I am sorry for delay (health problems). If this build wouldn't contain critical bugs, fulle version will follow.
Changes to 4.5.4 (2349)
News
added new block comments for CNC machines Okuma and Heller into User highlighter definition
New SAS parser for Code explorer
Corrections
Project settings - exception after click in external application list
Posted by: Helper | Date: 2009-07-07 07:03 | IP: IP Logged
Only one thing to tell you. Many thanks for your great job !
Sylvain.
Posted by: Lolo | Date: 2009-07-07 13:59 | IP: IP Logged
I have found a small bug (don't know if it already exists in previous version)
In order to reproduce the bug, open PSPad and paste the following sentence 10 times
You should have this :
"1234567980,
"1234567980,
"1234567980,
"1234567980,
"1234567980,
"1234567980,
"1234567980,
"1234567980,
"1234567980,
"1234567980,
Now, select a block (column block with Alt+Mouse) and try to delete the first two characters (Tab and ") on all lines (and do not forget to select the last line like screenshot bellow).
PSPad delete the block but also delete the character 1.
Can you reproduce the behavior?
Do you think you could correct it in the next release?
If you need my PSPad.ini, please, let me know.
Thanks in advance and have a nice day.
Posted by: zwayne | Date: 2009-07-07 22:01 | IP: IP Logged
Lolo - tested your scenario and I cannot replicate the problem with v2353.
Posted by: suraj.varma | Date: 2009-07-08 05:10 | IP: IP Logged
Well, I was able to replicate the bug... and I am running the latest 2353 build.
Instead of just deleting the first two characters (tab, double-quote), it is also deleting the next char (the number "1")
So, the final list shows up like this.
234567890,
234567890,
234567890,
234567890,
234567890,
Pressing Ctrl+Z does not get back the "1"s.
-Suraj
Posted by: hhoefling | Date: 2009-07-08 07:22 | IP: IP Logged
Quote:> Lolo - tested your scenario and I cannot replicate the problem with v2353.
You must activate "Scroll past EOL and EOF" in Editor-Options part 1
by HH
Edited 1 time(s). Last edit at 2009-07-08 07:23 by hhoefling.
Posted by: clanman | Date: 2009-07-09 10:35 | IP: IP Logged
In version 2351 the VBScript highlighter was changed to recognise the underscore (_) as a line continuation character.
Unfortunately (probably due to my miscommunication), PSPad is treating it as continuation character anywhere in the line and not only at the end of a line (or last character [excluding spaces] before a CRLF].
So what is happening is if for instance you have a variable called FOR_READING then the FOR section is taken as being the key wordfor
as in the looping constructFor Each
and not as part of the varible.
Posted by: Programmer | Date: 2009-07-09 14:57 | IP: IP Logged
I'm currently running 4.5.4 (2346).
Has this been fixed yet, or would it be possible to fix?
I just discovered an issue that when I try to print a document, it autowraps long lines, and if one of those is at the end of the page it wraps past the page margin and part of the line doesn't get printed. This should wrap to the next page.
Posted by: mce | Date: 2009-07-09 21:08 | IP: IP Logged
Thanks for this great editor, Jan.
I would like to submit a bug I noticed a while ago: in the Settings->Highlighter Settings->Compiler->Parameters I cannot use the | character (to allow me to grab the compiler output and process it further with another command), whenever I save and return back to the field the | gets replaced by a ", and it's not working. But I can use this trick just fine in the Project->Project Settings->Compiler->Parameters.
I know I could just write a batch file to call the compiler and the command after it, but I just wanted to raise this bug.
Another thing, I set my clips to expand on SPACE instead of CTRL+SPACE, and it's working fine, but I was wondering if it's possible or if there's a setting to not expand if I'm in the middle of entering a comment? For example, I don't want to expand an "if" when I'm writing it in a comment.
Thanks,
Cris
Posted by: pspad | Date: 2009-07-10 00:16 | IP: IP Logged
mce:Thanks for this great editor, Jan.
Thanks,
Cris
There isn't problem to write simple batch file and use it for compiler run. You can do anything inside your batch.
Ctrl+Space is general functionality, it doesn't recognize if it is in comment or not. If you don't want to expand it in comment, don't call it in comment.
