You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.4 (2346) English
Posted by: crimson | Date: 2009-03-25 16:22 | IP: IP Logged
HI!
I am using PSPad 2346. When I click the window close button, the PSPad will close but popup a message box with "Runtime error 204 at 00402f48". Does anybody like me?
Posted by: zforray | Date: 2009-03-25 18:14 | IP: IP Logged
crimson:HI!
I just tried it 4-times and I don't get the error. Are you sure you extracted all of the files from the latest version? What OS?
Posted by: crimson | Date: 2009-03-26 05:27 | IP: IP Logged
zforray:crimson:HI!
I am using PSPad 2346. When I click the window close button, the PSPad will close but popup a message box with "Runtime error 204 at 00402f48". Does anybody like me?I just tried it 4-times and I don't get the error. Are you sure you extracted all of the files from the latest version? What OS?
I use PSPad on 3 computers, all with XP. Two of 3 meet this condition. I only update PSPad.exe, tiny.exe and language file. Is it a problem?
Posted by: pspad | Date: 2009-03-27 14:15 | IP: IP Logged
crimson:I use PSPad on 3 computers, all with XP. Two of 3 meet this condition. I only update PSPad.exe, tiny.exe and language file. Is it a problem?
No, for PSpad run you need PSPad.EXE and .\Lang\English.INI only.
I don't meet this problem and has no report from others
Posted by: Joe Belmaati | Date: 2009-03-28 07:30 | IP: IP Logged
Dear Jan,
somehow the smarty highlighter went missing with this update. Any idea how to rectify this problem?
Thank you very much,
Joe Belmaati
Copenhagen Denmark
Posted by: Neil | Date: 2009-03-30 23:35 | IP: IP Logged
Hi Jan,
I have a problem with user defined clip.
My clip definition is:
[$(...$) | G Multiline Comment $(...$)]
which is used to insert the "$(" "$)" pairs around selected text.
This works fine.
The only problem is that if there is a "|" character in the selected text, PSpad goes to the first occurence of that character and deletes it.
Thanks
Neil
Posted by: vbr | Date: 2009-03-31 08:42 | IP: IP Logged
Neil:Hi Jan,I have a problem with user defined clip.
Thanks
Neil
See the discussion in an older thread:
forum.pspad.com
| is an implicit special character for cursor position
(as is § for the selected text)
You can set other characters (you aren't going to use in the source) by adding a special section to the clip file (...PSPad/Context/XXX.def)
Quote:[Clip Settings]
CursorChar=|
SelectionChar=§
Posted by: Neil | Date: 2009-03-31 21:14 | IP: IP Logged
vbr:Neil:Hi Jan,I have a problem with user defined clip.
Thanks
NeilSee the discussion in an older thread:
forum.pspad.com
(as is § for the selected text)You can set other characters (you aren't going to use in the source) by adding a special section to the clip file (...PSPad/Context/XXX.def)
CursorChar=|
SelectionChar=§vbr
Hi vbr,
Hey that is fantastic - this has been annoying me for months. I didn't think solution would be so simple.
Thanks again,
Neil
Posted by: Programmer | Date: 2009-04-10 20:54 | IP: IP Logged
I installed this 2346 update and I'm looking for English. The last update I attempted to install changed some menu options to a foreign language. This update fixed those but I still have some non-English menu options.
Under Scripts I have "Soubory v projektu" and "Ingkcpos"
Posted by: kiendlm | Date: 2009-04-10 21:26 | IP: IP Logged
Programmer:I installed this 2346 update and I'm looking for English. The last update I attempted to install changed some menu options to a foreign language. This update fixed those but I still have some non-English menu options.
The Menu texts in the Scripts menu don't come from the language file but from the scripts themself, and as PSPad is a czech program, the language you are seeing is czech. If you want to change those texts you have to go to the PSPad\Script directory and edit the script files. The Menu texts are set in the lines starting with "AddMenuItem".
