You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.4 (2341) English
Goto Page: Previous1 2 3 Next
#11 Re: PSPad unicode 4.5.4 (2341) English
Posted by: pspad | Date: 2009-02-16 16:58 | IP: IP Logged
carbonize:
Ilya:
Thank very much for the nice editor!
A very-very small error: the About Dialog shows the 2342 version, not 2341.
Ilya
At a guess that would be because the Delphi IDE automatically increments the build number with every compile and Jan had to compile a new version to fix the drag & drop issue which resulted in the build version getting increased by 1.
I don't have autoincrement activated. But I increase build number to be able make a difference between version with drop file problem and fixed version
#12 Re: PSPad unicode 4.5.4 (2341) English
Posted by: arek1 | Date: 2009-02-16 17:38 | IP: IP Logged
Same wish: Pleasesmiling smiley correct Wordwrap problem.
All the best.
#13 Re: PSPad unicode 4.5.4 (2341) English
Posted by: grep | Date: 2009-02-17 11:35 | IP: IP Logged
Just a small note.
In build 2342 the New file shortcut (Ctrl+N) is not working. Instead of this it adds a new line in the currently opened file.
No need to fixed just for me ... i fixed it with the resource editor. Everything else seems fine.
#14 Re: PSPad unicode 4.5.4 (2341) English
Posted by: pspad | Date: 2009-02-17 12:54 | IP: IP Logged
grep:
Just a small note.
Resource Editor? yawning smiley Next time use program settings / Keymap instead
#15 Re: PSPad unicode 4.5.4 (2341) English
Posted by: Ilya | Date: 2009-02-17 13:15 | IP: IP Logged
grep:
Just a small note.
I can confirm GREP's note:
2335 - the "Ctrl+N" opens a "New file.." dialog window. Like menu's File->New. The "Shift+Ctrl+N" opens a new file with a default extension without any dialog.
2342 - the Ctrl+N adds a new line in a opened file above cursor's position; and Shift+Ctrl+N - has the same behaivor as 2335 - opens default new file.
In both editors (on 2 machines) the Keymap is the same.
Edited 1 time(s). Last edit at 2009-02-17 13:17 by Ilya.
#16 Re: PSPad unicode 4.5.4 (2341) English
Posted by: grep | Date: 2009-02-17 14:08 | IP: IP Logged
I would say I feel quite ignorant right now - I never paid enough attention to this part of the options ... but it always feels better to go deep into the guts and tinker for a while smiling smiley
PS: 10x for the advice.
Edited 1 time(s). Last edit at 2009-02-17 14:12 by grep.
#17 Re: PSPad unicode 4.5.4 (2341) English
Posted by: MrSpock | Date: 2009-02-18 00:11 | IP: IP Logged
grep:
Just a small note.
I can't confirm this. Ctrl+N works normally for me in build 2342.
#18 Re: PSPad unicode 4.5.4 (2341) English
Posted by: anieden | Date: 2009-02-18 08:08 | IP: IP Logged
For me, when I start PSPad, the list of recently opened files is empty. It only becomes visible when I first close a file I am editing. Does anyone else see this, too?
#19 Re: PSPad unicode 4.5.4 (2341) English
Posted by: Anonymous User | Date: 2009-02-18 10:51 | IP: IP Logged
I can confirm this. Addition: 'Special/Recent files' becomes visible if you first choose 'Open selected...' from the toolbar.
#20 Re: PSPad unicode 4.5.4 (2342) English
Posted by: grep | Date: 2009-02-18 16:46 | IP: IP Logged
I also confirm that.
The menu open SPECIAL/RECENT shows the recent files after I open and then close a file or when I click the open SPECIAL/RECENT from the tool bar.
