You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.4 (2335) English
#51 Re: PSPad unicode 4.5.4 (2335) English
Posted by: pspad | Date: 2009-01-02 15:35 | IP: IP Logged
Helper:
Is it a bug or a misconfiguration ?
Using this version in "normal selection" mode is not working as usual.
- using up/down keys with a very long line from the EoL do not move you to the EoL of the previous/next line when it is shorter than the previous position.
- using left-clic of the mouse, clicking somewhere after the EoL do not place the cursor at the EoL.
Thanks in advance.
Program settings / Editor
Check if []Scroll past EOL is disabled
#52 Re: PSPad unicode 4.5.4 (2335) English
Posted by: vbr | Date: 2009-01-02 15:35 | IP: IP Logged
Helper:
Not sure about this, but didn't you activate scrolling past EOL/EOF somehow?
Settings :: Editor 1: [ ] Scroll past EOL and EOF
The described behaviour looks like this option is set.
hth
#53 Re: PSPad unicode 4.5.4 (2335) English
Posted by: fetis | Date: 2009-01-07 23:07 | IP: IP Logged
Hi, I got problem with file save.
I used PSPad 4.5.4.2315 before and 4.5.4.2335 now. All have this bug.
Problem appears with Firefox 3.
Steps to reproduce.
1. Create new HTML document.
2. Upload it somwhere. I used sendspace.com for example.
3. Try edit file now and save it.
Error
Error saving file XXXXX
OK
dialog box appears.
I tried this steps with Notepad and embedded Far Manager editor and got no errors.
I got same error message when I use Firebug 1.3 extension in Firefox.
Steps to reproduce.
1. Create new HTML document and open it in Firefox
2. Run Firebug.
3. Try edit file now and save it. The same error message appears
Please fix it! It's very annoying
#54 Re: PSPad unicode 4.5.4 (2335) English
Posted by: pspad | Date: 2009-01-08 19:03 | IP: IP Logged
fetis:
Steps to reproduce.
Error
OK
dialog box appears.
Steps to reproduce.
2. Run Firebug.
And you really thing it's a PSpad problem? Check if some other application dooesn't lock your file.
#55 Re: PSPad unicode 4.5.4 (2335) English
Posted by: fetis | Date: 2009-01-09 23:02 | IP: IP Logged
Yes. Here is my statistics (plus sign means editor can save file):
PSpad -
Notepad (WinXP SP2) +
Far Manager 1.71 +
Wordpad (WinXP SP2) -
Notepad++ 5.1.3.0 +
OpenOffice 2.0 Writer +
MS Office XP Word -
Delphi 2009 -
TopStyle 3.12 -
EditPlus 3.10 +
Alleycode 2.21 -
TotalEdit 5.0.8.0 -
MS Visual Stidio 2008 +
Cream (for Vim) 0.41 -
Vim 7.1 +
TextEdit 3.0, 4beta1 -
EditPadPro 6.0 +
UltraEdit 14.20 -
#56 Re: PSPad unicode 4.5.4 (2335) English
Posted by: bobbydj | Date: 2009-01-28 08:42 | IP: IP Logged
The text no longer recognized the syntax after 10913 lines of code ?
I use the Progress syntax.
#57 Re: PSPad unicode 4.5.4 (2335) English
Posted by: vbr | Date: 2009-01-28 17:40 | IP: IP Logged
bobbydj:
If the problem is, that the file isn't highlighted automatically after opening, the highlighter can be enabled in the toolbar or under the View menu.
Or you can increase the value of the filesize in
Settings :: Direct edit
HLOnUpToSize= xxx
#58 Re: PSPad unicode 4.5.4 (2335) English
Posted by: imiglikos2 | Date: 2009-01-29 09:54 | IP: IP Logged
Small comment to the German Version menu bar...
Instead of: File > New (German: Datei > Neu) appear Datei > Novy (Czech word?).
#59 Re: PSPad unicode 4.5.4 (2335) English
Posted by: Stefan | Date: 2009-01-29 12:45 | IP: IP Logged
imiglikos2:
===> forum.pspad.com Empty your browser cache and download again.
#60 Re: PSPad unicode 4.5.4 (2335) English
Posted by: Thralia | Date: 2009-01-29 14:50 | IP: IP Logged
imiglikos2:
Same thing with french version here.
