You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.4 (2331) English
Goto Page: Previous1 2 3 4 5 6 7 8 9 Next
Posted by: pspad | Date: 2008-10-30 19:12 | IP: IP Logged
Sorry, but I don't see active tab from your pictures.
Can you write some step by step how to simulate it?
Posted by: microalps | Date: 2008-10-30 21:21 | IP: IP Logged
I highlighted the tab that I hovered over. It happens to be the active one as well. Active and hover tabs have the orange bar to signify it's active/hover.
If I was able to provide you step by step how this happens, I would have done that. I don't know, but it's happened a third time today.
I would look into the cut and paste code, because that was the last thing I did when it happened the third time. I copied from one file, switched tabs, pasted, and saved. I got a notification that the tab I copied from changed. I looked at the file of the tab I pasted into, and it had adopted the other tabs name.
Edited 1 time(s). Last edit at 2008-10-30 21:24 by microalps.
Posted by: MarkRH | Date: 2008-11-03 00:53 | IP: IP Logged
Concerning those images... the forum software is chopping off the right part of the picture. With FireFox I can right-click the image and choose View Image to see the whole thing. Might try right-clicking and checking the image URL and viewing it directly.
Mark H.
Posted by: deanhill1971 | Date: 2008-11-05 13:54 | IP: IP Logged
I have a mouse with four buttons and a scroll wheel. In some of the recent builds of PSPad, the side mouse buttons (sometimes called X1 and X2) go forward and back through the file tabs (like pressing Ctrl+Tab and Ctrl+Shift+Tab).
Is there a way to turn this off? It interferes with how I have these buttons defined.
If it can't be turned off, I'll use Autohotkey to override the behavior.
Thanks.
Posted by: pspad | Date: 2008-11-05 20:07 | IP: IP Logged
deanhill1971:I have a mouse with four buttons and a scroll wheel. In some of the recent builds of PSPad, the side mouse buttons (sometimes called X1 and X2) go forward and back through the file tabs (like pressing Ctrl+Tab and Ctrl+Shift+Tab).Is there a way to turn this off? It interferes with how I have these buttons defined.
Not yet, but I can add option to Program settings.
Posted by: wjjchess | Date: 2008-11-18 08:25 | IP: IP Logged
thanks!
In 2331, It Open big file(6M), it very very slowly, it is not open in 3 minutes.
If the file's size > 1M, It open the file very slowly .
Posted by: pspad | Date: 2008-11-18 09:04 | IP: IP Logged
wjjchess:thanks!In 2331, It Open big file(6M), it very very slowly, it is not open in 3 minutes.
I don't agree. I am open files with tens of MB in seconds.
If file contains very long lines (tausands of chars), it can slow down PSpad.
Can you send me some of your file packed to support mail if it isn't confidental or private?
Try this:
Program settings / Editor
enable Scroll past EOL
Posted by: spawnua | Date: 2008-11-18 13:36 | IP: IP Logged
Thank you for FTP interface modifications! But when I change order of moveable columns, file sorting become incorrect.
Ukraine
Posted by: wjjchess | Date: 2008-11-18 13:42 | IP: IP Logged
pspad:wjjchess:thanks!In 2331, It Open big file(6M), it very very slowly, it is not open in 3 minutes.
Can you send me some of your file packed to support mail if it isn't confidental or private?Try this:
THANKS!!!
VERY GOOD!
AT NOW,“enable Scroll past EOL” is fast!!!
THANKS!!
THANKS!!
THANKS!!
THANKS!!
Posted by: pspad | Date: 2008-11-18 16:17 | IP: IP Logged
spawnua:Thank you for FTP interface modifications! But when I change order of moveable columns, file sorting become incorrect.
I found and fixed this bug.
