You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.4 (2325) English
#31 Re: PSPad unicode 4.5.4 (2325) English
Posted by: Thinker | Date: 2008-08-03 10:53 | IP: IP Logged
One more thing:
I upgraded 2320 to 2325 and now, when FTP tab is active Save To FTP key shortcut doesn't work, I need to click on code and then hit the key.
#32 Re: PSPad unicode 4.5.4 (2325) English
Posted by: pspad | Date: 2008-08-03 11:24 | IP: IP Logged
What Shortcut did you assing for Save to FTP?
#33 Re: PSPad unicode 4.5.4 (2325) English
Posted by: Thinker | Date: 2008-08-04 16:33 | IP: IP Logged
F2.
#34 Re: PSPad unicode 4.5.4 (2325) English
Posted by: pspad | Date: 2008-08-04 16:40 | IP: IP Logged
F2 is standard shortcut for rename in tree.
#35 Re: PSPad unicode 4.5.4 (2325) English
Posted by: Eblis | Date: 2008-08-04 20:11 | IP: IP Logged
Did you find out the cause of the toolbar weird height ?
#36 Re: PSPad unicode 4.5.4 (2325) English
Posted by: Thinker | Date: 2008-08-05 11:07 | IP: IP Logged
So it's now impossible to use F2? :( It was always possible..
#37 Re: PSPad unicode 4.5.4 (2325) English
Posted by: pspad | Date: 2008-08-05 11:16 | IP: IP Logged
Not in FTP or File explorer window
#38 Re: PSPad unicode 4.5.4 (2325) English
Posted by: asherriff | Date: 2008-08-11 11:22 | IP: IP Logged
I have noticed a problem with highlighting keywords when the words contain a "-".
I have created a custom Syntax for OpenEdge 10 (Progress). The keywords in this language have a "-" separating them
e.g. ADD­-CALC­-COLUMN
I have created the ADD­-CALC­-COLUMN in the definition
and also added "-" in allowed charcter in keywords.
However when I open a file with this keyword in the color is not shown correctly it shows with ADD and COLUMN in highlighted color and CALC in black. The "-" character is also in Black. Further investigation shows that ADD and COLUMN are also in the definition list and if I remove them the whole keyword appears in black.
Any thoughts ?
#39 Re: PSPad unicode 4.5.4 (2325) English
Posted by: pspad | Date: 2008-08-11 11:38 | IP: IP Logged
asherriff:
And you set highlighter to what comment?
#40 Re: PSPad unicode 4.5.4 (2325) English
Posted by: deanhill1971 | Date: 2008-08-12 14:46 | IP: IP Logged
I just installed this build, but the C# Code Explorer doesn't seem to work.
I've opened multiple C# files, and I've only been able to see one Code Explorer entry. The below C# line shows up under the Function group:
[assembly: log4net.Config.XmlConfigurator(ConfigFile = "TexasScanStation.exe.config", Watch = false)]
