You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.4 (2325) English
#11 Re: PSPad unicode 4.5.4 (2325) English
Posted by: pspad | Date: 2008-07-23 14:41 | IP: IP Logged
Colors are #nnn or #nnnnnn (n is a numeric)
I can start comment if # isn't follow by number, but I don't know how acceptable is it.
#12 Re: PSPad unicode 4.5.4 (2325) English
Posted by: RickH | Date: 2008-07-23 14:48 | IP: IP Logged
Jan,
Thanks for the js code explorer change. It will be really helpful. The different colors for "private" and "public" methods will also a great help.
Rick
#13 Re: PSPad unicode 4.5.4 (2325) English
Posted by: tyzio | Date: 2008-07-24 07:55 | IP: IP Logged
For me is very OK.
I guess n is hex number therefore to make the comment highlighting more clear maybe you could start comment if # isn't follow by any number or letter.
Thanks.
#14 Re: PSPad unicode 4.5.4 (2325) English
Posted by: Whitewater | Date: 2008-07-24 17:04 | IP: IP Logged
Screen rendering is fast again!
Thank you very much, Jan!
ciao,
Thomas
#15 Re: PSPad unicode 4.5.4 (2325) English
Posted by: venki | Date: 2008-07-25 09:11 | IP: IP Logged
I tried to delete few characters by using backspace or delete key but nothing happens. This seems to be a bug in the latest build 2325.
I am not sure whether others faced a similar problem.
#16 Re: PSPad unicode 4.5.4 (2325) English
Posted by: Ao | Date: 2008-07-25 11:33 | IP: IP Logged
venki:
It will seem a bit obvious, but have you checked whether the file was read-only or not ?
#17 Re: PSPad unicode 4.5.4 (2325) English
Posted by: venki | Date: 2008-07-27 09:41 | IP: IP Logged
No its not a read only file. I have checked it. I have tried to extract the cab file again but still the same effect. I am only able to select the text and use the menu to delete the selected text. Otherwise I am unable to use the backspace and delete keys.
#18 Re: PSPad unicode 4.5.4 (2325) English
Posted by: vbr | Date: 2008-07-27 11:00 | IP: IP Logged
venki:
You may try to unpack PSPad into another folder, so you have a fresh install, and check your problem again; if this would work, there might be a problem with the setting PSPad.INI, or the internal program chache file PSCache.BIN could be corrupted.
(alternatively you can also temporarily rename these files and see if something changes); I think, some similar problem has been mentioned here in forum, but I don't remember the details and am not able to find it just now.
#19 Re: PSPad unicode 4.5.4 (2325) English
Posted by: wjjchess | Date: 2008-07-27 11:36 | IP: IP Logged
at first, thanks
in 2325 version , it read big file slow.
#20 Re: PSPad unicode 4.5.4 (2325) English
Posted by: wjjchess | Date: 2008-07-27 11:43 | IP: IP Logged
thanks,
when a opened file is deleted,
it hope pspad can prompt "the file already delete"
