You are here: PSPad forum > Developer forum - new builds > PSPad and TopStyle Lite 3.50
#1 PSPad and TopStyle Lite 3.50
Posted by: pspad | Date: 07/01/2008 17:08 | IP: IP Logged
Because new TopStyle Lite 3.50 version doesn't register itself as COM server, it isn't possible to use it in PSPad.
You have 2 ways how to do it:
1. install TopStyle Lite 3.10 and reinstal it with TopStyle Lite 3.50 without uninstall or simply replace files in TopStyle folder (EXE and DLL) with new version.
2. Download this smal package:
www.pspad.com
It contains 2 REG files. One reister TopStyle (both) in Windows registry second REG file delete registry entries.
You need to have administrator right to do it (right mouse and Run as administrator under Vista).
Edited 2 time(s). Last edit at 07/03/2008 06:45 by pspad.
#2 Re: PSPad and TopStyle Lite 3.50
Posted by: michal.kolesa | Date: 10/03/2008 20:55 | IP: IP Logged
Vzhledem k tomu, že nová verze TopStyle Lite 3.50 neregistruje jako server COM, není možné jej používat v PSPad.
Máte 2 způsoby, jak to udělat:
1. TopStyle Lite 3.10 nainstalovat znovu, a to s TopStyle Lite 3.50 bez odinstalovat nebo jednoduše nahradit soubory ve složce TopStyle (EXE a DLL) s novou verzí.
2. Download this smal package: Stáhněte si tento balíček Smal:
www.pspad.com
Jeden reister TopStyle (obojí) v registru systému Windows druhé REG soubor smazat položky registru.
Musíte mít práva správce, aby to udělal (pravé myši a spustit jako administrátor pod Vista).
S pozdravem
Michal Kolesa
michal.kolesa@seznam.cz
#3 Re: PSPad and TopStyle Lite 3.50
Posted by: jokmontoya | Date: 09/16/2009 22:10 | IP: IP Logged
I have modified the TopStyle_registration.reg file, so it now works on spanish Windows. In spanish windows, "Program Files" is named "Archivos de programa" some paths in the reg file need to be modified, "C:\\PROGRA~1\\" to "C:\\ARCHIV~1\\" and "C:\\Program Files\\" to "C:\\Archivos de programa\\".
This is the code in the file TopStyle_registration.reg for Spanish windows:
Intructions in spanish:
(ES) Copia y pega el codigo que se encuentra entre las lineas, no incluidas, en un archivo de texto, renombra la extensión a ".reg" y ejecutalo haciendo doble click, esto hara que se registre debidamente el TopStyle Lite 3.5 para que PsPad lo detecte bien.
REGEDIT4
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\TopStyleLite.Application]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\TopStyleLite.Application\Clsid]
@="{9A0EB8C5-3ADB-11D3-BCEE-00C04F72DA55}"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{9A0EB8C5-3ADB-11D3-BCEE-00C04F72DA55}]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{9A0EB8C5-3ADB-11D3-BCEE-00C04F72DA55}\LocalServer32]
@="C:\\ARCHIV~1\\Bradbury\\TSLite3\\TSLite3.exe"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{9A0EB8C5-3ADB-11D3-BCEE-00C04F72DA55}\ProgID]
@="TopStyleLite.Application"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{9A0EB8C5-3ADB-11D3-BCEE-00C04F72DA55}\TypeLib]
@="{5C21BCD5-F27A-11D2-BB98-00C04F72DA55}"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{9A0EB8C5-3ADB-11D3-BCEE-00C04F72DA55}\Version]
@="3.0"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Interface\{9A0EB8C3-3ADB-11D3-BCEE-00C04F72DA55}]
@="IApplication"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Interface\{9A0EB8C3-3ADB-11D3-BCEE-00C04F72DA55}\ProxyStubClsid]
@="{00020424-0000-0000-C000-000000000046}"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Interface\{9A0EB8C3-3ADB-11D3-BCEE-00C04F72DA55}\ProxyStubClsid32]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Interface\{9A0EB8C3-3ADB-11D3-BCEE-00C04F72DA55}\TypeLib]
"Version"="3.0"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\TypeLib\{5C21BCD5-F27A-11D2-BB98-00C04F72DA55}\3.0]
@="TopStyle Lite Library"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\TypeLib\{5C21BCD5-F27A-11D2-BB98-00C04F72DA55}\3.0\0\win32]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\TypeLib\{5C21BCD5-F27A-11D2-BB98-00C04F72DA55}\3.0\FLAGS]
@="0"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\TypeLib\{5C21BCD5-F27A-11D2-BB98-00C04F72DA55}\3.0\HELPDIR]
@="C:\\ARCHIV~1\\Bradbury\\TSLite3\\"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\TypeLib\{5C21BCD5-F27A-11D2-BB98-00C04F72DA55}\3.5]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\TypeLib\{5C21BCD5-F27A-11D2-BB98-00C04F72DA55}\3.5\0\win32]
@="C:\\Archivos de programa\\Bradbury\\TSLite3\\TSLite3.exe"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\TypeLib\{5C21BCD5-F27A-11D2-BB98-00C04F72DA55}\3.5\FLAGS]
@="0"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\TypeLib\{5C21BCD5-F27A-11D2-BB98-00C04F72DA55}\3.5\HELPDIR]
@="C:\\Archivos de programa\\Bradbury\\TSLite3\\"
The unregistration file, don't need to be modified.
(ES) El archivo para eliminarlo del registro no necesita ser modificado, puedes usar el que está en el fichero del post inicial.
Edited 1 time(s). Last edit at 09/16/2009 22:11 by jokmontoya.
#4 Re: PSPad and TopStyle Lite 3.50
Posted by: Hymer | Date: 06/16/2010 21:30 | IP: IP Logged
I downloaded and extracted TopStyle registration and unregister, but now I don't know what to do with them. I have TopStyle Lite 3.5 on my computer.
#5 Re: PSPad and TopStyle Lite 3.50
Posted by: carbonize | Date: 06/23/2010 21:35 | IP: IP Logged
Double click the register file and just allow it when asked.
Carbonize
#6 Re: PSPad and TopStyle Lite 3.50
Posted by: Bitz | Date: 07/14/2010 13:53 | IP: IP Logged
That is exactly what I needed, thank you.
Bitz
#7 Re: PSPad and TopStyle Lite 3.50
Posted by: tcblack | Date: 09/01/2011 16:07 | IP: IP Logged
For windows 7 X64 you'll have to edit the registration file and change progra~1 to progra~2. Also change "program files" to "Program files (x86)".
There are two of each.
Here's the final reg that worked for me:
REGEDIT4
@="C:\\PROGRA~2\\Bradbury\\TSLite3\\TSLite3.exe"
@="3.0"
@="IApplication"
"Version"="3.0"
@="0"
@="C:\\PROGRA~2\\Bradbury\\TSLite3\\"
@="C:\\Program Files (x86)\\Bradbury\\TSLite3\\TSLite3.exe"
@="0"
@="C:\\Program Files (x86)\\Bradbury\\TSLite3\\"
