You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.4 (2320) English
Goto Page: Previous1 2 3 4 5 6
#51 Re: PSPad unicode 4.5.4 (2320) English
Posted by: pspad | Date: 2008-07-10 16:21 | IP: IP Logged
There are two FTP secure protocols - SFTP and FTPS.
I am afraid you are trying to use SFTP what isn't supported yet.
#52 Re: PSPad unicode 4.5.4 (2320) English
Posted by: Lolo Irie | Date: 2008-07-11 12:21 | IP: IP Logged
Not sure if the problem is opnly with this rleease, like i'm not testing all dev releases...
In the log parser debuger:
Try:
Log text: 45
Parser Exp: %L
Result 45
Log text: 45
Parser Exp: %C
Result nothing
Log text: c:\test\tmp.txt
Parser Exp: %F
Result nothing
looks like only "Line" is correctly working.
Or did I miss something ?
Thanks for a short info about.
Cheers
etalkers.org
#53 Re: PSPad unicode 4.5.4 (2320) English
Posted by: wednesday | Date: 2008-07-16 17:20 | IP: IP Logged
Hi, I'm testing this version since a few weeks and recognized a rather annoying change of behavior:
When I open a file in the project window, it is sent to the default application instead of being opened in PSPad (which was the case in 4.5.3). Is this a feature decision, or did I just overlook the option to make the "Open as Text" option the default action? I don't want to link each and every file type with PSPad on my system.
#54 Re: PSPad unicode 4.5.4 (2320) English
Posted by: pspad | Date: 2008-07-20 15:22 | IP: IP Logged
PSPad opens it's know files in PSPad (extension exists in some highighter), rest of files is open in default application.
In previous version was bug - for you maybe wanted.
#55 Re: PSPad unicode 4.5.4 (2320) English
Posted by: pspad | Date: 2008-07-22 09:10 | IP: IP Logged
Lived:
Input relative path to help file for php files in "Highlighters settings" menu, like "..\..\docs\php_manual_ru.chm".
The warning is frequently displayed:
"External help for PHP isn't assigned.
Got to the Highlighter settings to assign external help file."
Sometimes all ok.
P.S. "HTML multihighlighter" disabled.
Use %PSPath% in your help variable. Modify your help path to:
%PSPath%..\..\Docs\php_manual_ru.chm
