You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.4 (2320) English
#41 Re: PSPad unicode 4.5.4 (2320) English
Posted by: vbr | Date: 2008-06-23 16:10 | IP: IP Logged
macok10:
I downloaded last version 4.5.4 (2320) and noticed that tab switching is not working like it was in previous versions.
You may check the setting in
Program settings :: Program 2: Tab switching
and choose the appropriate behaviour for you.
#42 Re: PSPad unicode 4.5.4 (2320) English
Posted by: Lived | Date: 2008-06-24 12:59 | IP: IP Logged
Input relative path to help file for php files in "Highlighters settings" menu, like "..\..\docs\php_manual_ru.chm".
The warning is frequently displayed:
"External help for PHP isn't assigned.
Got to the Highlighter settings to assign external help file."
Sometimes all ok.
P.S. "HTML multihighlighter" disabled.
#43 Re: PSPad unicode 4.5.4 (2320) English
Posted by: gwinkless | Date: 2008-06-25 12:13 | IP: IP Logged
Changing to full screen mode does nothing until you load a new file (or switch tabs). Unsure if this is new to this version or if it's an existing bug (I've never tried it before).
Geoff
#44 Re: PSPad unicode 4.5.4 (2320) English
Posted by: refardt | Date: 2008-06-30 20:28 | IP: IP Logged
I have sometimes to open TXT-files with a size till 200 MB (sometimes bigger).
The actual and previous versions won't open such big files.
It's possible to you implementing this feature in the next version?
Many thanks in front.
Juergen
Edited 1 time(s). Last edit at 2008-06-30 20:28 by refardt.
#45 Re: PSPad unicode 4.5.4 (2320) English
Posted by: pspad | Date: 2008-07-01 04:09 | IP: IP Logged
refardt:
Juergen
This isn't feature.
PSPad loads whole file into memory. Load such big file takes a time.
Try to switch on cursor after EOL option in the program settings editor
#46 Re: PSPad unicode 4.5.4 (2320) English
Posted by: refardt | Date: 2008-07-01 14:58 | IP: IP Logged
PsPad shows a windows with the following message:
"File xxxxxxx could not opened"
PsPad instead open a new empty txt-file tab.
Switching "allow cursor after EOL" is on, because without the loadtime of the files is very long.
Juergen
#47 Re: PSPad unicode 4.5.4 (2320) English
Posted by: Thinker | Date: 2008-07-05 17:01 | IP: IP Logged
There is still problem with opening tabs in Vista.
When PSPad is maximized at start, every tab makes 1 blik of Vista Aero taskbar.
Blink means it turns transparent like when there is no maximized window, and then it goes solid color (like with maximized window).
#48 Re: PSPad unicode 4.5.4 (2320) English
Posted by: Patrik | Date: 2008-07-10 07:54 | IP: IP Logged
I have one question for future features development. I believe that you have long, long list of features you would like to implement.
Is there any way how to publish this list (or at least part of this list) and let users to vote which features should be implemented first?
This should also show you in which way PSPad should be developed.
Thanks a lot and I hope that this is not too daring
Patrik
#49 Re: PSPad unicode 4.5.4 (2320) English
Posted by: cebe | Date: 2008-07-10 09:10 | IP: IP Logged
FTP - added TLS/SSL support using OpenSSL (both DLL libraries have to exist in the PSPad folder). Secure connection is indicated with other yellow icons on the FTP panel.
Update TextDiff component, first version of the line differences in the window bottom. Speed was improved.
WONDERFUL !! SUPER MEGA CLASSE !!
The End of 3 years waiting, using winscp+pspad !
Thanks a lot ! smiling smiley
#50 Re: PSPad unicode 4.5.4 (2320) English
Posted by: pcskibum | Date: 2008-07-10 13:49 | IP: IP Logged
I was also very excited to see the addition of SFTP, but I can't make it work. I receive these messages:
07:30:39 >> Can't connect
07:30:39 >> LastError: 10054
I have placed ssleay32.dll and libeay32.dll into the main PSPad directory.
When using WinSCP to connect to the same server with SFTP there is no problem.
I see no connection attempts in the server log, so it looks like PSPad is not even trying to connect.
Any idea where I should look for a problem?
Version 4.5.4 (2320) running on Windows XP
