You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.4 (2320) English
Posted by: Lolo | Date: 2008-06-16 13:03 | IP: IP Logged
Thanks for this new build
I have notice a small bug with Text Diff.
Here is the way to reproduce the problem:
- Simply create two files with a blanck line at the end and compare them.
PSPad detects a difference on the last line whereas it is not true.
More, the text for the last difference (on the bottom) stay active.
Is it normal?
Concerning my "Text difference" parameters, the 3 checkboxes are checked.
Please let me know if you need more informations.
Thanks and have a nice day.
Posted by: NoSi | Date: 2008-06-20 09:42 | IP: IP Logged
regarding to German Umlauts I think, I have found the circumstances:
If I load an exixting TXT-file, the UTF-8 "boom" (identbytes) are obviously not set, if the file has not. The only workaround is creating a really new file ("save as" does not fix) and save this. Then the content is recognized by other editors correct. Otherwise the German umlauts are replaced by whatever.
I tried this in 2320. If required, please, ask for sample files.
Greetings
NOSi
Posted by: pspad | Date: 2008-06-22 07:04 | IP: IP Logged
If file dosn't contains BOM, there is only possibility to recognize code page via file content. This method isn't 100%.
If yu open file and PSPad doesn't recognize correct Code page, change code page in the format menu and do Reload (Ctrl+L)
Please check, if in the Program setings / Files or Project settings isn't set code page. In this case PSpad will open all files in specified code page.
Posted by: Joe Belmaati | Date: 2008-06-22 12:21 | IP: IP Logged
Hello Jan,
after installing 2320 I get an error that MSVCR71.dll is missing. The prompt repeats three times after which PSPad opens and - seemingly - works. I tried to search the forum for an answer to this problem, but I did not find anything. Any help is appreciated.
(Using WinXP SP2)
Sincerely,
Joe Belmaati
Copenhagen Denmark
Edited 1 time(s). Last edit at 2008-06-22 12:27 by Joe Belmaati.
Posted by: pspad | Date: 2008-06-22 12:36 | IP: IP Logged
There is a problem (I don't understand), joined with libraries for SSL/TSL secured connection.
If you delete new two DLL libraries in PSPad folder, problem will gone.
I need to find a problem reason.
Edited 1 time(s). Last edit at 2008-06-22 12:37 by pspad.
Posted by: Joe Belmaati | Date: 2008-06-22 13:09 | IP: IP Logged
Yes, that works. Thank you very much.
Posted by: mali_zeeko | Date: 2008-06-22 16:55 | IP: IP Logged
These two DLL-s depend on MSVCR71.DLL which is part of VS2003. To solve this problem MSVCR71.DLL must be
in PsPad folder, or somewhere in path. libeay32.dll
and libssl32.dll are part of OpenSLL.
Latest OpenSLL source can be downloaded from www.openssl.org. There is also link to installer with windows binaries, including needed DLL-s.
Posted by: pspad | Date: 2008-06-22 17:48 | IP: IP Logged
MS VC++ Runtime is part of many MS applications.
I thing better will be provided download links instead distribute distribute theses libraries.
Posted by: NoSi | Date: 2008-06-23 08:26 | IP: IP Logged
pspad:If yu open file and PSPad doesn't recognize correct Code page, change code page in the format menu and do Reload (Ctrl+L)Please check, if in the Program setings / Files or Project settings isn't set code page. In this case PSpad will open all files in specified code page.
Thanks for this hint. In settings I preset UTF-8, and this format is displayed in file-format. PSPad opens the files correct, other editors do not. Regardless PSPad displayes the settings as given in preset but obviously this is not the preset, it is the estimated format, recognised on load - maybe this is my confusion. I thought, that the displayed format is forced on save.
Not shure if this is realy required and/or usful, but maybe it could help, if the format is not checked, instead a dot (or whatever) shows, that the displayed format is the one PSPad considers, and not the one, the file carries i.e. with a "bom".
With reloading the file is stored new and everything is fine. Good to know.
Best Regards,
NoSi
Posted by: macok10 | Date: 2008-06-23 16:02 | IP: IP Logged
I downloaded last version 4.5.4 (2320) and noticed that tab switching is not working like it was in previous versions.
