You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.4 (2320) English
Goto Page: 1 2 3 4 5 6 Next
#1 PSPad unicode 4.5.4 (2320) English
Posted by: pspad | Date: 2008-06-09 16:39 | IP: IP Logged
Download links (1.7 MB):
pspad.siliconhill.cz
pspad.cincura.net
Changes to 4.5.4 (2317)
Known issues
Slow file loading
News
FTP - added TLS/SSL support using OpenSSL (both DLL libraries have to exist in the PSPad folder). Secure connection is indicated with other yellow icons on the FTP panel.
Update TextDiff component, first version of the line differences in the window bottom. Speed was improved.
Corrections
PHP Code explorer - function in classes
LOG window - font size
LOG window - scroll bar autowidth with script and List style
reformat XML
Splitted window - width of the gutter in the second window
TextDiff - goto line in the first window
#2 Re: PSPad unicode 4.5.4 (2320) English
Posted by: Marten | Date: 2008-06-09 17:41 | IP: IP Logged
After installing the patch I get the following message:
The ordinal 968 could not be located in the dynamic link library LIBEAY32.dll
sad smiley
Edited 1 time(s). Last edit at 2008-06-09 17:42 by Marten.
#3 Re: PSPad unicode 4.5.4 (2320) English
Posted by: pspad | Date: 2008-06-09 18:07 | IP: IP Logged
Your operating system?
You can delete this (or both DLL).
You can try to download latest Windows OpenSSL binaries
Edited 2 time(s). Last edit at 2008-06-10 17:30 by pspad.
#4 Re: PSPad unicode 4.5.4 (2320) English
Posted by: MrSpock | Date: 2008-06-09 18:08 | IP: IP Logged
Thanks for the new build. In the online.ini, the link to the Unicode HOWTO somehow went into the Python section, though I think it's of general interest.
EDIT: Ah, now I see I was wrong, sorry.
Edited 1 time(s). Last edit at 2008-06-09 18:19 by MrSpock.
#5 Re: PSPad unicode 4.5.4 (2320) English
Posted by: Marten | Date: 2008-06-09 18:50 | IP: IP Logged
Marten:
sad smiley
My OS is Windows XPSP3. Deleting the dll solves the problem.
#6 Re: PSPad unicode 4.5.4 (2320) English
Posted by: pspad | Date: 2008-06-09 19:28 | IP: IP Logged
Marten:
I have same system with no problem. We will see the net reactions. This libraries ae necessary for secure FTP tarnsfers only and are optional.
#7 Re: PSPad unicode 4.5.4 (2320) English
Posted by: MrSpock | Date: 2008-06-09 23:24 | IP: IP Logged
I've skipped a few betas and I just discovered the new text diff feature that displays the differences in a line. Very helpful. Thank you.
#8 Re: PSPad unicode 4.5.4 (2320) English
Posted by: Nelson | Date: 2008-06-10 03:05 | IP: IP Logged
There is a bug with the new TextDiff.
The "line difference" feature can't display non-English words correctly.
#9 Re: PSPad unicode 4.5.4 (2320) English
Posted by: pspad | Date: 2008-06-10 06:43 | IP: IP Logged
Nelson:
It was a first step for implementation. In the next version will be unicode support for this too.
#10 Re: PSPad unicode 4.5.4 (2320) English
Posted by: gurbao | Date: 2008-06-10 11:28 | IP: IP Logged
what is the reason for the new list logwindow?
I find it much harder to view large output when I have to scroll back and forth, up and down.
Or are there settings available to control the size of the log area?
Regards,
