You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.4 (2317) English
Goto Page: Previous1 2 3 Next
#11 Re: PSPad unicode 4.5.4 (2317) English
Posted by: nTE | Date: 2008-05-28 13:41 | IP: IP Logged
Problem found and fixed
Thank you very much! :)
#12 Re: PSPad unicode 4.5.4 (2317) English
Posted by: Funbug | Date: 2008-05-29 07:41 | IP: IP Logged
Funbug:
Okay, but it would be nice if they were imported anyway. Without TLS.
No problem, I will remove condition
Thanks! smiling smiley
#13 Re: PSPad unicode 4.5.4 (2317) English
Posted by: freebear | Date: 2008-05-29 08:49 | IP: IP Logged
when I replace all files with 2317 cab, I found File->Session didn't to work.
#14 Re: PSPad unicode 4.5.4 (2317) English
Posted by: pspad | Date: 2008-05-29 08:57 | IP: IP Logged
freebear:
Can you be more specific? What doesn't work?
How can I simulate your problem?
#15 Re: PSPad unicode 4.5.4 (2317) English
Posted by: freebear | Date: 2008-05-29 11:09 | IP: IP Logged
thinks.
save session... and session manager... can be work,
but when I click session name before saved, nothing to opened.
when I selected "Close files first before open new session" , it's OK, clicked all session name can be opened.
Edited 2 time(s). Last edit at 2008-05-29 11:21 by freebear.
#16 Re: PSPad unicode 4.5.4 (2317) English
Posted by: pspad | Date: 2008-05-29 11:25 | IP: IP Logged
freebear:
thinks.
OK, I will check it.
Edited 1 time(s). Last edit at 2008-05-29 11:26 by pspad.
#17 Re: PSPad unicode 4.5.4 (2317) English
Posted by: Joske | Date: 2008-05-30 07:09 | IP: IP Logged
The correction "FTP - on some servers PSPad cuts first 2 chars from filename"
Still doesn't work for me !
I have mentioned this problem since version 4.5.3 (2298)
on 09/01/2008 (ICQ : 23032692)
#18 Re: PSPad unicode 4.5.4 (2317) English
Posted by: pspad | Date: 2008-05-30 08:11 | IP: IP Logged
Joske:
I need LIST output from your FTP server in attacment via mail.
I don't understand, why each FTP server has own file list result. To parse and recognize it is very problematic.
#19 Re: PSPad unicode 4.5.4 (2317) English
Posted by: Tecno | Date: 2008-05-31 18:49 | IP: IP Logged
PSPad has a problem, it's not new, it also happened in older versions, but keeps happening:
When you press the "Enter" key, to create a new line, after you wrote a line of code, it jumps to the created line, but adds some tabs or spaces to it automatically. It should not do this ! It is an annoying bug, could you please fix this ? Sometimes when you aren't paying attention to it, it can cause some unexpected problems.
It would be so great if you fixed it ! Thanks ! smiling smiley
P.S: If you enable the "Show/Hide spaces, tabs & line ends" button, and open a file, and press enter a couple of times to create new code lines, you will see this happen.
Ah another thing I just noticed: JCL Hi lighting is wrong, it only works when JCL code starts on column 7 of the editor/file, but JCL files are normally coded to start right from column 1, not 7 like COBOL.
Edited 2 time(s). Last edit at 2008-05-31 19:02 by Tecno.
#20 Re: PSPad unicode 4.5.4 (2317) English
Posted by: pspad | Date: 2008-05-31 19:38 | IP: IP Logged
Tecno:
Switch off autoindent option in the Program settings
