You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.4 (2315) English
Posted by: Whitewater | Date: 2008-04-09 15:40 | IP: IP Logged
hankejh:Hi MarkRH,
Did you notice any improvement with screen painting after renaming your pspad.ini? I just upgraded to 2315 from 2278 (which was working without any issues for me) and while I did not experience slow loading (even from an SFtpDrive mounted volume), when I switch between applications and then back to PSPad, the screen paints very slow. Screen rendering was instant with 2278.
You are right, screen rendering is very slow since 2303. It prevents me from upgrading. 2301 was still fine, the issue occured between 2301 and 2303.
This has NOTHING to to with Syntax Highlighting or pspad.ini. Even if i delete pspad.ini and turn off syntax highlighting, the problem occurs. It not only slows down switching between applications, but also scrolling in a large file (PGUP/PGDOWN or using the mouse with the scrollbar).
This is really annoying, because I fear I can never upgrade because of that problem ...
ciao,
Whitewater
Posted by: MarkRH | Date: 2008-04-10 05:30 | IP: IP Logged
No, my screen repaints fine. I can drag windows with their contents showing over pspad fine. I never had any real problems with the screen repainting or redrawing itself.
Mark H.
Posted by: hankejh | Date: 2008-04-10 15:06 | IP: IP Logged
Whitewater:You are right, screen rendering is very slow since 2303. It prevents me from upgrading. 2301 was still fine, the issue occured between 2301 and 2303.
I had to roll back to 2278. The screen painting is ridiculously slow - line by line repaints on Restore/Maximize, PAGE-UP/DN and indenting. It definitely has nothing to do with my DVI video card (ATI Radeon x1550 Series, 512mb, 400MHz DAC).
Posted by: zuperman | Date: 2008-04-14 12:21 | IP: IP Logged
hello
Just tried out this new build for the SQR code explorer functionality. I just copied the contents of the .cab file over my existing installation (clean last official release). A few of my remarks, don't know whether they are all normal :
- I lost all my settings: my previous settings for SQR highlighting, language changed back from English to Dutch, ...
- The code explorer is not saying "Not implemented for this file type" anymore for SQR, but it is not showing any contents. (I thought it would automatically show a list of functions used in my .sqr file?)
Seeing all this, I suppose I did something wrong with 'just' copying the cab file?
Thanks for the great work!
Erik
Posted by: pspad | Date: 2008-04-14 17:47 | IP: IP Logged
All theeses settings you talk about is stored in the PSPad.INI what isn't contained in the PSPadxxx.cab
Did you set the ftSQR in the FileType field in SQR user highlighter definition?
Posted by: wichien | Date: 2008-04-17 03:19 | IP: IP Logged
Hi
I cannot download this version. When I click pspad.siliconhill.cz , it displayed
IWSS Security Event (BAYIWSS)
InterScan Web Security detected malicious code in your web traffic:
Item: pspad.siliconhill.cz
Action: deleted
Infection detail:
-- File: PSPadShell.dll, Enclosure: pspad454b2315.cab, malicious code name: PAK_Generic.005
The uncleanable file is deleted.
Posted by: pspad | Date: 2008-04-17 08:39 | IP: IP Logged
Use mirror or use connection from otherwhere.
Sorry, but I am not responsible for paranoid antivirus.
Posted by: zuperman | Date: 2008-04-25 08:33 | IP: IP Logged
pspad:All theeses settings you talk about is stored in the PSPad.INI what isn't contained in the PSPadxxx.cab
solved! many thanks!
i didn't backup pspad.ini as I installed it in my personal folder and not included in the installation folder. with re-installing I selected the correct option . and indeed ftSQR did the job.
Posted by: jgodfrey | Date: 2008-04-30 20:08 | IP: IP Logged
Hi Jan,
Using 2315, the following (valid) Tcl code seems to confuse PSPad's brace matching logic...
part_deletePart {
set expList {
{string equal $nodeInfo(type) part}
{expr ![db::recordExists dbMem "select 1 from repostruct \
where parentID = '$id'"]}
The first and last brace actually match, but PSPad seems to be confused by the quoted string that's split across 2 lines via the "\" character. It seems to think the double quote in the 2nd line of the quoted string is actually an opening quote instead of a close quote, so I guess it thinks the brace at the end of that line is part of a quoted string.
This is not a 2315 specific issue.
Side note - is there a way to keep code formatting (indent, etc) in a forum thread?
Thanks,
Jeff
Posted by: GNUBIE | Date: 2008-05-02 14:27 | IP: IP Logged
What does it mean: Unpack it with subfolders and replace existing files from the last full release.
I've downloaded the zip. I can open it, but then do what?
Regards,
GN
