You are here: PSPad forum > Developer forum > PSPad unicode 4.5.4 (2309) English
Goto Page: 1 2 3 4 Next
#1 PSPad unicode 4.5.4 (2309) English
Posted by: pspad | Date: 03/01/2008 11:30 | IP: IP Logged
Download links (1.7 MB):
pspad.siliconhill.cz
pspad.cincura.net
Changes to 4.5.4 (2308)
Known issues
Character relicts when autoindent and real tabs are on.
News
added Sessions support - it allows you save/restore open files state (session)
C# code explorer
Remove nonexisting recent files (menu Open / Special or menu next open button)
Corrections
TextDiff exception
FTP client - problem with date if FTP server doesn't sent complete file date
#2 Re: PSPad unicode 4.5.4 (2309) English
Posted by: Replika | Date: 03/01/2008 17:02 | IP: IP Logged
- added Sessions support - it allows you save/restore open files state (session)
- C# code explorer
wow!!! Many thanks for your hard works
#3 Re: PSPad unicode 4.5.4 (2309) English
Posted by: Karl | Date: 03/01/2008 18:52 | IP: IP Logged
Thanks for another version. Strangely, this release seems to be even slower on startup than r2308. The difference between r2309 and 2301 loading my sessions is now staggering.
Is there any chance that a future version will address this problem?
K.
#4 Re: PSPad unicode 4.5.4 (2309) English
Posted by: Fuci | Date: 03/01/2008 21:34 | IP: IP Logged
Thank you so much for this update. It's a testament to how amazing PSPad is that not being able to use it over the past day or so greatly impacted my work.
Thanks for the quick updates!
#5 Re: PSPad unicode 4.5.4 (2309) English
Posted by: pspad | Date: 03/01/2008 21:44 | IP: IP Logged
Karl:
K.
Please can you test this build (PSPad.EXE only)?
pspad.cincura.net
I returned back changes I made.
This build fixes problem with fantom characters too.
#6 Re: PSPad unicode 4.5.4 (2309) English
Posted by: Billy | Date: 03/01/2008 22:47 | IP: IP Logged
pspad.cincura.net
File is not on this mirror. Get it here:
#7 Re: PSPad unicode 4.5.4 (2309) English
Posted by: Jume | Date: 03/02/2008 10:34 | IP: IP Logged
thank you very much for the sessions, they work flawlessly grinning smiley
on a side note, when you press ALT to make appear in the dialogs the underlined chars, in most dialogs there are controls that dissapear (buttons, labels, etc), mostly when the focus is in a text box, but not necesarily
as im not sure if it is something related to my config i guess its better if another people can confirm it or not
running vista x32, and im not sure since when this is happening as im not that much alt+key user, though in the last translation update i did i think it was not there (4.5.3 2298)
#8 Re: PSPad unicode 4.5.4 (2309) English
Posted by: muthukrish_2000 | Date: 03/03/2008 05:27 | IP: IP Logged
Thanks for the new build.The text difference is working fine without exception.smiling smiley
#9 Re: PSPad unicode 4.5.4 (2309) English
Posted by: Karl | Date: 03/03/2008 09:11 | IP: IP Logged
Karl:
K.
pspad.cincura.net
Alas, this one actually feels slower than r2309 and r2308. It takes ages until the edit window appears.
r2301 is still the last usable version for me.
K.
#10 Re: PSPad unicode 4.5.4 (2309) English
Posted by: pspad | Date: 03/03/2008 10:01 | IP: IP Logged
Did you run PSPad from local drive or network?
Operating system?
I try to find a reason, but I don't know nothing what should have influence.
Editor PSPad - freeware editor, © 2001 - 2010 Jan Fiala
