You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 4.5.4 (2303) English
Goto Page: Previous1 2 3 4
#31 Re: PSPad unicode 4.5.4 (2303) English
Posted by: pspad | Date: 2008-02-25 16:18 | IP: IP Logged
Jocho:
Hi Jan !
Your logSetTypeMmo and logSetTypeList are great, thanks very much smiling smiley
A logSetParserExpr and log will be perfect.
Just a remark: if log line contains "error" and "errors", the line is not marked as error.
Jo
Send me sample of such LOG line
#32 Re: PSPad unicode 4.5.4 (2303) English
Posted by: pspad | Date: 2008-02-25 16:42 | IP: IP Logged
Marten:
Hi Jan,
In releases before 4.5.4 (build 2301) after compilation the editor was opend on the line of the first error. Is this option removed from the LOG window or is it a matter of a wrong configuration?
Regards,
Marten
As I test it, PSPad set the error log line. I need to know your compiler settings.
#33 Re: PSPad unicode 4.5.4 (2303) English
Posted by: Jocho | Date: 2008-02-25 17:06 | IP: IP Logged
It's not a problem for me, but I've seen it so I've noticed it.
Line "error" is marked as error.
Line "error error" is marked as error.
Line "error errors" is not marked as error.
Line "errors" is not marked as error.
It happens in a line like "Error: Can't......... Too many errors, stopping." or "Build failed: 6 errors found".
I think it's about "no errors" issue ?
Regards,
Jo
#34 Re: PSPad unicode 4.5.4 (2303) English
Posted by: pspad | Date: 2008-02-25 19:33 | IP: IP Logged
"Build failed: 6 errors found" - I don't mean it's line containing information about error
#35 Re: PSPad unicode 4.5.4 (2303) English
Posted by: jgodfrey | Date: 2008-02-26 15:03 | IP: IP Logged
Tcl/Tk highlighter doesn't work with escaped strings. Corrected.
Confirmed fixed in 2308. Highlighting and bracket matching now work in the described situation.
Great work - thanks Jan!
Jeff
#36 Re: PSPad unicode 4.5.4 (2303) English
Posted by: Marten | Date: 2008-03-05 12:58 | IP: IP Logged
Dear Jan,
The problem seems to be resolved.
regards,
Marten
