You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.3 (2297) English
Posted by: mathiasm | Date: 2007-11-27 01:52 | IP: IP Logged
But should not this build belong to 4.5.4 series, respectfully to other post titles ??
Posted by: pspad | Date: 2007-11-27 04:54 | IP: IP Logged
IF you notice, I update 4.5.3 full release and now will start 4.5.4 builds.
Posted by: Fraerok | Date: 2007-11-27 11:15 | IP: IP Logged
When was 2298 released?
Why we haven't information about this?)
Posted by: pspad | Date: 2007-11-27 12:35 | IP: IP Logged
Fraerok:When was 2298 released?
2298 is a 4.5.3 full release. PSPad pages are full of information of this release.
Posted by: RickH | Date: 2007-11-28 14:47 | IP: IP Logged
The filetab problem that seemed to appear in 2296 still exists. I lose the bottom tabs whenever I open a file that needs another row. I can get them back by cycling the "File Tabs - Panel on Top" option. I can also click on a mostly hidden tab to access it, but that doesn't restore the row. Running Windows 2000.
Keep up the great work!
Posted by: mathiasm | Date: 2007-11-28 20:54 | IP: IP Logged
oups, i thought it was already relased by a previous build (2291).
Sorry, I missed the point.
Posted by: tyzio | Date: 2007-11-29 09:03 | IP: IP Logged
Today I found that LOG parser for Compiler or Favorite Tools are not working correctly in this version. I mean, LOG parser is correctly configured in in debug mode works OK but when I run compiler and then I double click at error line in LOG Window there is no transition to selected line.
I check 2296 version and it works correctly with the same pspad.ini and files.
Posted by: MrSpock | Date: 2007-11-29 09:40 | IP: IP Logged
tyzio:Hi,Today I found that LOG parser for Compiler or Favorite Tools are not working correctly in this version. I mean, LOG parser is correctly configured in in debug mode works OK but when I run compiler and then I double click at error line in LOG Window there is no transition to selected line.
Confirmed. Applies to 2298 too.
Posted by: tyzio | Date: 2007-11-29 13:01 | IP: IP Logged
Another findings:
I've started to create hot clips for mediawiki, so I created mediawiki syntax file (ini) and I edited the DEF file and put there:
[bold | make selection bold]*Ctrl+Shift+B
[cBlue | make selection blue]
<font color="blue">§</font>
[cBlue | make selection red]
<font color="red">§</font>
When I start using it I found that the clips doesn't work every time when they are executed. Recovery is to switch to other open document (Ctrl+Tab) and back and that clips start working for short time.
I'm not able to find repeatable scenario for this; sometimes clips stop working after first usage and sometimes after severals.
Other thing is that when I select some text and call Hot Clips window (Ctrl+Space), not all clips are listed (e.g. selection'cB' text cause that clips with cB at the beginning are listed only).
Posted by: molinarm | Date: 2007-11-29 15:17 | IP: IP Logged
Jan,
thanks a lot for this new beta!
I can confirm that the regression of C functions disappearing from C/C++ Code Explorer function list, which had showed up since beta 2281, has now been fixed.
Well done!
Mario Molinari
