You are here: PSPad forum > Developer forum > PSPad unicode 4.5.3 (2297) English
Posted by: pspad | Date: 11/25/2007 17:37 | IP: IP Logged
Download links (1.7 MB):
pspad.cincura.net
Changes to 4.5.3 (2296)
News
Corrections
Opn file from selection doesn't work for folders
LOGs and results in unicode
File tab - last line was hide in some cases
Slow double click on File tab with FlatButtons style changes cursor to drop icon
Search in files - recent folders history wasn't stored
C++ Code Explorer and conditions
Import from RTF doesn't work for unicode RTF
Incremental search - exception after paste
Posted by: MrSpock | Date: 11/25/2007 19:54 | IP: IP Logged
Thanks for the new build. Your hard work is much appreciated.
This is very unimportant, but anyhow: In recent builds, the file PSCache.bin is included in the CAB archives. I don't think this is intentional?
Posted by: pspad | Date: 11/25/2007 20:13 | IP: IP Logged
Of course not, thank you.
Posted by: Marten | Date: 11/26/2007 10:28 | IP: IP Logged
There is a minor problem with the pspad-install. The install program tries to create the file readme.rtf as a directory.
Posted by: gurbao | Date: 11/26/2007 14:00 | IP: IP Logged
the memo-styled logwindow now capture unicode output
Thanks for your hard work.
Regards,
Posted by: Lolo | Date: 11/26/2007 21:46 | IP: IP Logged
Marten:There is a minor problem with the pspad-install. The install program tries to create the file readme.rtf as a directory.
I can confirm this problem if any recent beta already installed.
There is no problem with a new installation.
Posted by: pspad | Date: 11/26/2007 21:56 | IP: IP Logged
I modified script - a stupid typo
But I have no power to upload packages right now...
Posted by: Programmer | Date: 11/26/2007 22:26 | IP: IP Logged
The good news: With this update my toolbars finally display initially on the left (got rid of blank space in the middle).
The bad news: Toolbars behaving oddly if you click and drag them. (not a major issue since I don't normally do this and restarting fixes it)
Posted by: Fraerok | Date: 11/26/2007 23:09 | IP: IP Logged
Update checker is showing last version is 4.5.3 (2298). How it may be?
Posted by: pspad | Date: 11/26/2007 23:32 | IP: IP Logged
Fraerok:Update checker is showing last version is 4.5.3 (2298). How it may be?
because the latest full release is really 2298
Editor PSPad - freeware editor, © 2001 - 2010 Jan Fiala
