You are here: PSPad forum > Developer forum > PSPad unicode 4.5.3 (2296) English
Posted by: pspad | Date: 11/20/2007 21:43 | IP: IP Logged
Download links (1.7 MB):
pspad.cincura.net
pspad.siliconhill.cz
Changes to 4.5.3 (2295)
News
Corrections
Find word under cursor doesn't works with Whole word program settings
New TXT file as first line and nonprinted chars
Numeric base translator - OK button doesn't close form
program doesn't remeber Tollbars panel state
File from FTP and function Save to FTP
Posted by: Lolo | Date: 11/21/2007 16:01 | IP: IP Logged
Thanks for this new release.
I noticed a small cosmetic bug (do not know if it has appeared in this release)
Create two files with long filename (without quote) :
"000000.AAAAA.BBBBBB.S.ABCDEFGHIJKLMNOPQRS TUVWXYZ_123456 78901234_211107_1200.SSSSS.XXX.FFFFFFF.21112007152125"
and
"000000.AAAAA.BBBBBB.E.ABCDEFGHIJKLMNOPQRS TUVWXYZ_123456 78901234_211107_1200.SSSSS.XXX.FFFFFFF.21112007152125"
Now open the first one and then the second one.
The tab is not shown on screen (see screenshot)
For information I am on Windows 2000 sp4 and my screen resolution is 1280x1024
Could you reproduce this behavior?
More, it seems there is a small blank line on the top of toolbar (between menu and toolbar). Am I right or not?
Thanks and have a nice day.
Posted by: mathiasm | Date: 11/21/2007 16:41 | IP: IP Logged
Should not it be PSPad unicode 4.5.4 (2296) English ?
Posted by: stefangabos | Date: 11/21/2007 18:33 | IP: IP Logged
i also have my tab hidden when i open up around 12 files with name not longer than 20 chars. if you can't reproduce this i'll also send you my file names...
Posted by: pspad | Date: 11/21/2007 19:48 | IP: IP Logged
mathiasm:Should not it be PSPad unicode 4.5.4 (2296) English ?
No, because 4.5.3 full contains some bugs. I need to correct it and release new full version
Posted by: MrSpock | Date: 11/21/2007 20:46 | IP: IP Logged
stefangabos:i also have my tab hidden when i open up around 12 files with name not longer than 20 chars. if you can't reproduce this i'll also send you my file names...
Perhaps related? I can see my second row of tabs, but the third one is hidden:
I don't think this was there in earlier builds.
EDIT: In case somebody is wondering why the filenames mention weapons, these are scripts for a 1st person shooter bot. See www.omni-bot.de. I'm not a terrorist, nor am I involved with the Mafia or anything of the kind.
Edited 1 time(s). Last edit at 11/21/2007 20:56 by MrSpock.
Posted by: gurbao | Date: 11/22/2007 10:04 | IP: IP Logged
I guess you (Jan) is aware of that the memo- and liststyle logwindow does not work as expected with what I belive is unicode output?
This is the same as I reported for release 2293.
Regards,
Edited 1 time(s). Last edit at 11/22/2007 10:05 by gurbao.
Posted by: pspad | Date: 11/22/2007 12:07 | IP: IP Logged
gurbao:Hi,I guess you (Jan) is aware of that the memo- and liststyle logwindow does not work as expected with what I belive is unicode output?
This is the same as I reported for release 2293.Regards,
You are right, I need some small time to replace it with unicode components
Posted by: pspad | Date: 11/22/2007 13:31 | IP: IP Logged
Lolo:Hello,Thanks for this new release.
I noticed a small cosmetic bug (do not know if it has appeared in this release)Create two files with long filename (without quote) :
and
Correction will be availeble in the next build
Posted by: Lolo | Date: 11/22/2007 16:30 | IP: IP Logged
pspad:Correction will be availeble in the next build
Thank you very much.
Editor PSPad - freeware editor, © 2001 - 2010 Jan Fiala
