You are here: PSPad forum > Developer forum > PSPad unicode 4.5.3 (2295) English
Posted by: pspad | Date: 11/16/2007 21:55 | IP: IP Logged
Download links (1.7 MB):
pspad.cincura.net
pspad.siliconhill.cz
Changes to 4.5.3 (2293)
News
Corrections
Scripting - projectFilesCount() returns bad files count
C++ Code explorer and conditions
Command line Window and Win9x
and many small bugs correction
Posted by: stefangabos | Date: 11/17/2007 10:41 | IP: IP Logged
i am not using the toolbar. so i press f2 and it dissappears. but starting with 2291 it doesn't remembers that i hide it and everytime i start pspad the toolbar is visible again
Posted by: Marten | Date: 11/18/2007 15:42 | IP: IP Logged
The LOG window complete with the red bullets seems to behave well now!
Edited 1 time(s). Last edit at 11/18/2007 15:42 by Marten.
Posted by: pypardo | Date: 11/19/2007 15:09 | IP: IP Logged
Hi all,
I experience a *really* strange feature (in fact a real bug).
I create a new tab (ctrl N) and select text file.
I paste my data.
I press Ctrl-S to save my file but pspad do not open save dialog box.
If I create a new tab (ctrl N) and type something, I can save my file.
It seems to be related to my clipboard content (data from excel).
In both case, there's a red mark on tabs (data modified).
Best regards
pierre
Posted by: vbr | Date: 11/19/2007 19:14 | IP: IP Logged
pypardo:I paste my data.
Not sure about this, but you may check the content of the first line, which gets pasted (as well as written) in it. See:
forum.pspad.com
(There is a new function assigning the content of the first file as the filename of new files - without a highlighter; I guess there were some problems with this.).
Posted by: pypardo | Date: 11/19/2007 19:19 | IP: IP Logged
thanks for reply
i'll check if I can reproduce problem and create a procedure for this.
this is not in fact a real problem, because workaround are easy.
best regards
pierre
Posted by: janaco | Date: 11/20/2007 00:13 | IP: IP Logged
pypardo:i'll check if I can reproduce problem and create a procedure for this.
Have a look if a Tab (0x9) is used anywhere in the first line. Seems to be a bug as vbr mentioned. Any unprintable Characters prevent saving dialog.
Posted by: Jody | Date: 11/20/2007 03:44 | IP: IP Logged
Still not stable.
Started new txt file pasted a few paragraphs.
Opened another new txt file (tab) and pasted a paragraph of text and program crashed (access violation).
I was too busy to send info but I'll try and recreate and send.
Jody
Posted by: pypardo | Date: 11/20/2007 09:31 | IP: IP Logged
janaco:pypardo:i'll check if I can reproduce problem and create a procedure for this.Have a look if a Tab (0x9) is used anywhere in the first line. Seems to be a bug as vbr mentioned. Any unprintable Characters prevent saving dialog.
You're right, if a tab (0x9) is present on first line, dialog box does not appears.
It's not a big problem for me.
Best regards
thanks for tips...
Pierre
Posted by: pspad | Date: 11/20/2007 21:21 | IP: IP Logged
stefangabos:i am not using the toolbar. so i press f2 and it dissappears. but starting with 2291 it doesn't remembers that i hide it and everytime i start pspad the toolbar is visible again
Confirmed, corrected
Editor PSPad - freeware editor, © 2001 - 2010 Jan Fiala
