You are here: PSPad forum > Developer forum > PSPad unicode 4.5.3 (2293) English
Posted by: pspad | Date: 11/13/2007 18:37 | IP: IP Logged
Download links (1.7 MB):
pspad.cincura.net
pspad.siliconhill.cz
Changes to 4.5.3 (2291)
News
new function - Shift+clik on the Script menuitem opens script source instead run it
new parameter in the [Special settings] (Program settings / Direct edit) - TransparencyLevel (0..255) allows you set trasparency for main window. Lower value means higher transarency.
Corrections
External command doesn't set Log window type
File tabs for 2 and more files doesn't work after start
FTP client and VMS server
Scripting support - function openFileFromFTP() doesn't actualize FTP window content
In the LIST mode LOG content was in lowercase
User highlighter and words starts with # or ;
Block selector icon after F8 on the statusba
Exception after align to block
Matching symbols highlighting
Save HEX file doesn't set Archive attribut
Compilator with catch output causes exception in some cases
Posted by: MrSpock | Date: 11/13/2007 19:48 | IP: IP Logged
pspad:News
Excellent idea! Very helpful, thanks!
Posted by: pspad | Date: 11/13/2007 19:51 | IP: IP Logged
I thing about way to show script file without writing special edit script function and this was a simply way how to do it.
I need confirmation if memory problems continue or not.
If this build will be more stable, I will update 4.5.3 full version.
Posted by: MrSpock | Date: 11/13/2007 20:54 | IP: IP Logged
We will need a few days to make sure. The problems with the last build weren't obvious; they only showed up after some days of using PSPad for me.
It's kind of a sad irony that almost all the beta versions in the last months were far more stable than the official release version build 2291.
Posted by: mce | Date: 11/14/2007 05:12 | IP: IP Logged
Can you check this when you have time, I'm trying to set-up this as a compiler:
Compiler: c:\compile.bat
Parameters:
-p c:\compile.p | c:\tee.exe C:\compile.log
Log File: c:\work\compile.log
tee.exe is part of the UnxUtils, a collection of Unix commands for Windows, which permits you to see the result of a command on screen and also save it to a file.
This setup works fine from the Project compiler but not from the generic compiler, every time I save this in the generic compiler the | gets replaced by " and the command doesn't work as expected. A similar setup works also fine from the Favorite tools, just the generic compiler doesn't run it like this.
Thank you,
Cristian
Posted by: mce | Date: 11/14/2007 05:14 | IP: IP Logged
I made a typo, the Log File is C:\compile.log, same as saved by the tee command.
Thanks,
Cristian
Posted by: thomas | Date: 11/14/2007 09:10 | IP: IP Logged
The problem with the messed-up toolbars (see thread about 2291 build) seems to be fixed as well with this build.
Thanks
Posted by: gurbao | Date: 11/14/2007 10:01 | IP: IP Logged
The memo-style logwindow also works when using external commands instead of compiler
Thanks a lot.
Posted by: erema | Date: 11/14/2007 12:07 | IP: IP Logged
pspad:I need confirmation if memory problems continue or not.
PSPad still crashes in some cases, but now without "invalid pointer operation (etc)" alert - just closes.
Editor PSPad - freeware editor, © 2001 - 2010 Jan Fiala
