You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.3 (2291) English
Posted by: Zappa | Date: 2007-11-06 18:23 | IP: IP Logged
pspad:Bug confirmed and corrected
Fine, thanks.
ZAP
Posted by: Eblis | Date: 2007-11-06 20:40 | IP: IP Logged
Feature request:
Option to confirm file open for files larger than a specified size.
I have pspad set to the F4 key in my file manager and I sometimes hit it by accident on a huge (1G, 2G) file and my system freezes while pspad tries to open the file (kill process doens't work, it won't kill it instantly)
It would be nice if pspad would ask if you're sure you want to open the file if it exceeds a certain size (configurable in the options maybe).
Posted by: gurbao | Date: 2007-11-06 22:12 | IP: IP Logged
Memo-logwindow problem solution:
Posted by: fubo | Date: 2007-11-07 09:40 | IP: IP Logged
Hi all,
Code explorer for C is broken from last beta release. Basically a line like "if( ... )" is treated as a function because it ends without ";", so it's reported in Function pane.
Posted by: thomas | Date: 2007-11-07 18:38 | IP: IP Logged
Programmer:On startup I get a huge blank space beside the Print/Preview toolbuttons. If I adjust to fit it comes back on next startup. This is annoying.
Same here when switching off some of the toolbars.
Posted by: Fraerok | Date: 2007-11-07 22:34 | IP: IP Logged
Request: toolbar position save
Question: Will be soon new final version (with repairs) realesed?
Posted by: Whitewater | Date: 2007-11-08 16:43 | IP: IP Logged
There is a problem now with braket highlighting.
The highlighting itself is correct, but when you position the cursor elsewhere, the background color always resets to white, even if there is another background color set:
ciao,
Thomas
Posted by: Stefan | Date: 2007-11-09 09:22 | IP: IP Logged
Whitewater:There is a problem now with braket highlighting.The highlighting itself is correct, but when you position the cursor elsewhere, the background color always resets to white, even if there is another background color set:
Thomas
That's no bug. That's a new feature. So you know always which brakets you have allready checked
Posted by: erema | Date: 2007-11-09 13:04 | IP: IP Logged
when pspad's window is maximized (not in "FullScreen Mode"), closing last tab leads terrible blinking - editor field getting ~30% smaller and then blinks 4-5 times (about 1.5 second total). (Vista home Basic, screen resolution 1280*800).
also, often pressing F11 leads window to maximize; close button, icon & window title disappear; but menu line isn't redrawed until some actions like "New file".
Posted by: yn | Date: 2007-11-11 13:15 | IP: IP Logged
I've experienced a weird problem since my 1st try long time ago :
I use Python as the compiler, and as long as Python process is running, PSPAD stop responding. But if I capture console output, this problem doesn't show up.
Does this ever happen to any1 of you ?
Thx.
