You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.3 (2291) English
#11 Re: PSPad unicode 4.5.3 (2291) English
Posted by: Programmer | Date: 2007-11-05 21:40 | IP: IP Logged
You know, it looks like this.
#12 Re: PSPad unicode 4.5.3 (2291) English
Posted by: Zappa | Date: 2007-11-05 22:17 | IP: IP Logged
That's right. I've had three files open, tested now with two up to twenty. When PSpad is reopened the tab bar is hidden. When opening another file (or switching the preferences to 'Always..') it gets visible.
ZAP
#13 Re: PSPad unicode 4.5.3 (2291) English
Posted by: gurbao | Date: 2007-11-06 09:16 | IP: IP Logged
Not able to get memo-style logwindow to work sad smiley
At least not for SQL queries.
Can somebody please confirm?
#14 Re: PSPad unicode 4.5.3 (2291) English
Posted by: pspad | Date: 2007-11-06 09:33 | IP: IP Logged
If you use projects, check project settings.
#15 Re: PSPad unicode 4.5.3 (2291) English
Posted by: Mihawk90 | Date: 2007-11-06 10:52 | IP: IP Logged
to the toolbars... no problem for me ^^ when I rearrange tthe toolbars, and restart PSPad, everythings right :D no problems. OK, the positions aren't sevaed, but there's no space between the toolbars smiling smiley
Sorry for the bad English, if it's bad :D
Edited 1 time(s). Last edit at 2007-11-06 10:52 by Mihawk90.
#16 Re: PSPad unicode 4.5.3 (2291) English
Posted by: ckx | Date: 2007-11-06 11:38 | IP: IP Logged
I've had the toolbar problem too. There's no gap if the HTML toolbar is included (my current settings are everything except the project toolbar). But hiding the HTML toolbar results in a gap next time PSPad is started. (PSPad is still an awesome editor nonetheless).
#17 Re: PSPad unicode 4.5.3 (2291) English
Posted by: Mihawk90 | Date: 2007-11-06 11:42 | IP: IP Logged
Hmm, I let the toolbars how they was... I never changed them^^ because I don't needed to change^^
PS: running Win98^^
#18 Re: PSPad unicode 4.5.3 (2291) English
Posted by: gurbao | Date: 2007-11-06 12:53 | IP: IP Logged
Memo logwindow:
I usually don't use projects, but created one now for a quick test.
Does not work sad smiley
I always get the list logwindow no matter what settings I use in "User highlighter" and "project settings"...
#19 Re: PSPad unicode 4.5.3 (2291) English
Posted by: pspad | Date: 2007-11-06 14:12 | IP: IP Logged
I found a problem.
It doesn't work for external application, but if you use compiler first, it is OK.
Use compiler instead external application up to problem will be corrected.
#20 Re: PSPad unicode 4.5.3 (2291) English
Posted by: pspad | Date: 2007-11-06 16:10 | IP: IP Logged
Zappa:
ZAP
Bug confirmed and corrected
