You are here: PSPad forum > Developer forum > PSPad unicode 4.5.3 (2284) English
Goto Page: 1 2 3 Next
#1 PSPad unicode 4.5.3 (2284) English
Posted by: pspad | Date: 10/28/2007 19:00 | IP: IP Logged
Download links (1.7 MB):
pspad.cincura.net
Changes to 4.5.3 (2283)
News
Scripting - new function runPSPadAction() allows you to run any PSPad action. Action list and example is in the .\Script\readme.txt file. You can e.g. run user convertor for all open files.
Expression evaluator, Color translator, Numeric base calculator are nonmodal now
Corrections
C++ Code explorer has problem with functions within namespace
highlight matching expressions when curent line isn't highlighted
#2 Re: PSPad unicode 4.5.3 (2284) English
Posted by: MrSpock | Date: 10/28/2007 19:14 | IP: IP Logged
Did you maybe forget to update the build number? The English version I just downloaded still says it is build 2283.
#3 Re: PSPad unicode 4.5.3 (2284) English
Posted by: pspad | Date: 10/28/2007 19:23 | IP: IP Logged
I am very sorry, I forgot upload new PSPad.exe into package sad smiley
Already uploading new version. Try it please in several minutes.
#4 Re: PSPad unicode 4.5.3 (2284) English
Posted by: MrSpock | Date: 10/28/2007 19:30 | IP: IP Logged
No problem. smiling smiley With the huge workload you are handling all the time, I'd expect things like this to happen more often.
#5 Re: PSPad unicode 4.5.3 (2284) English
Posted by: tyzio | Date: 10/29/2007 08:50 | IP: IP Logged
That was fastyawning smiley.
Thanks for nonmodal windowsgrinning smileygrinning smiley
I checked also problem with switching memo<->list LOG compiler style. It seems to be working correctly with this build.
#6 Re: PSPad unicode 4.5.3 (2284) English
Posted by: naputtelija | Date: 10/29/2007 09:44 | IP: IP Logged
I don't know if this is new problem or not, but I just noticed this: Make a new txt file, write character '<' or '|' on the first line and you cannot save file. File dialog does not show up.
#7 Re: PSPad unicode 4.5.3 (2284) English
Posted by: gurbao | Date: 10/29/2007 09:54 | IP: IP Logged
I really appreciate your work on the log window, giving us users the ability to choose between list and memo style.
But, is it possible to have this "Log window type"-choise also for "External applications" ?
Thanks,
#8 Re: PSPad unicode 4.5.3 (2284) English
Posted by: pspad | Date: 10/29/2007 10:31 | IP: IP Logged
It should take a settings from highlighter compiler
#9 Re: PSPad unicode 4.5.3 (2284) English
Posted by: gurbao | Date: 10/29/2007 11:27 | IP: IP Logged
yes sorry, it didn't work first time.
I installed 2284 again and now it works grinning smiley
Thanks,
#10 Re: PSPad unicode 4.5.3 (2284) English
Posted by: gurbao | Date: 10/29/2007 15:06 | IP: IP Logged
I am having some small problems with using memo in logwindow.
When I restart Pspad, it always uses list in logwindow when running my sql script as external application, even though the "Compilator logtype" is 1 in pspad.ini.
As far as I can understand 1 means memo and 0 means list.
If I then run a logparser script (set up as compiler with memo), this will use memo in logwindow and all sql scripts will then also use memo in logwindow.
Anyone that can confirm this just to be sure this is not a "local" problem...
Thanks,
Editor PSPad - freeware editor, © 2001 - 2010 Jan Fiala
