You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.3 (2282) English
Posted by: kosthala | Date: 2007-10-17 16:26 | IP: IP Logged
I'm sorry but i can't reproduce the crash any more!
The code is the same, with the same error in the same position, but i don't get any crash.
I will be back if i have any news.
Posted by: SteveLeBlanc | Date: 2007-10-17 18:03 | IP: IP Logged
pspad:The assignLog() function is no longer supported in PSPad v4.5.3. You can directly access the LOG with the new log functions. Log is no longer able to simulate editor window functionality.
Thank you. That clears things up for me. You need to add the above line to the Script\readme.rtf file. And remove the reference to AssignLog() under the section called "editor object function"
Posted by: pspad | Date: 2007-10-17 19:05 | IP: IP Logged
OK. I will do it, or I can add AssignLog back and let it return some value you can make an universal scripts...
P.S.
OK. I will return it back and it will returns always 0 (before it returns 1).
Edited 1 time(s). Last edit at 2007-10-17 19:10 by pspad.
Posted by: mathiasm | Date: 2007-10-17 23:50 | IP: IP Logged
Do you plan to add a button or a menu to clear the log window ?
Posted by: pspad | Date: 2007-10-18 04:40 | IP: IP Logged
mathiasm:Do you plan to add a button or a menu to clear the log window ?
I don't see any reason for it. Log is automatically cleared with new compiler call.
You can write simple script what can do it if you need it. See new logXXXX function in scripting support
Posted by: gurbao | Date: 2007-10-18 09:41 | IP: IP Logged
I mostly use the logwindow for capturing output running sql, powershell, scripts etc (not much compiling).
I never even noticed any problems with the logwindow
With the new logwindow I cannot longer copy values etc from it.
Is this just me or is this not longer doable?
As you understand, I am still using the 2281 build
Regards,
Posted by: pspad | Date: 2007-10-18 09:57 | IP: IP Logged
You can copy whole content now only or open it in new window.
Posted by: Deesy | Date: 2007-10-19 12:29 | IP: IP Logged
gurbao:As you understand, I am still using the 2281 build
Same for me - came back to 2281
Posted by: pspad | Date: 2007-10-19 13:24 | IP: IP Logged
OK. What now? I can't use editor in the log, because it has drawing problems.
If I use ListBox, there is no possibility to select part of the text.
I can use memo, but without marking lines with errors.
At this time ListBox is used and will be used in future too, if no other solution will be available.
Posted by: estmatic | Date: 2007-10-19 14:22 | IP: IP Logged
Maybe an option to switch between the current list-based view and a simpler memo-based view would do the trick.
The memo view would just keep appending stuff to the bottom. No special features or formatting, just plain text. That would allow people to select/copy anything they need out of it. The list view would have all the extra features when users are compiling code and such.
Edited 1 time(s). Last edit at 2007-10-19 14:22 by estmatic.
