You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 4.5.3 (2280) English
Goto Page: Previous1 2 3
#21 Re: PSPad unicode 4.5.3 (2280) English
Posted by: himila | Date: 2007-10-06 16:23 | IP: IP Logged
Edit by mod:
By an advice of the author!
Hello, thanks for the report, but please
do not post such "Access violation" logs into the forum,
but post only an hint that you have this error
and send the error log itself to the Author Jan by email! (sup p ort - a't - pspad - c0m)
Thanks for the report and your comprehension.
The mod.
OK, post the log because i'm afraid of my poor english,so you may be not understand what i said.
the second, i thought the forum is the place of bug collection......
NOW,i know where the logs should be sent, thank you .
#22 Re: PSPad unicode 4.5.3 (2280) English
Posted by: Mrtb | Date: 2007-10-06 18:45 | IP: IP Logged
I LOVE PsPad and I need to know when a new version will be released.
Thanks so MUCH!
And Good WORK!
#23 Re: PSPad unicode 4.5.3 (2280) English
Posted by: kiendlm | Date: 2007-10-06 19:26 | IP: IP Logged
himila:
hi, one bug in the 2280 version.
whenever you select chinese or english language for pspad, then when you click format--font,you will see the dialog box still dispaly in chinese language(maybe because i use the chinese os.)
Yes, himla, that's the point. The language of the font selection dialog comes from the OS, not from PSPad because this is a common dialog supplied by the OS.
himila:
, and whatever you click(OK or CANCEL) it still will get application error, say
I can confirm this bug. It seems to be a general issue, because I get it with a german Windows XP SP2 and PSPad set to german language as well.
#24 Re: PSPad unicode 4.5.3 (2280) English
Posted by: himila | Date: 2007-10-07 06:29 | IP: IP Logged
kiendlm:
himila:
i found that if you open pspad with a new blank file(directly open pspad by pspad.exe),the problem what i said will occur, and if you open a file which is not blank , the bug is not occur.
i just test a .txt file and a .dat file
thanks
Edited 1 time(s). Last edit at 2007-10-07 06:35 by himila.
