You are here: PSPad forum > Developer forum > PSPad unicode 4.5.3 (2277) English
Goto Page: 1 2 3 Next
#1 PSPad unicode 4.5.3 (2277) English
Posted by: pspad | Date: 09/23/2007 17:52 | IP: IP Logged
Download links (1.7 MB):
pspad.cincura.net
ftp.siliconhill.cz
Changes to 4.5.3 (2275)
News
Program settings / Program - Smart file switch has 3 mode (combo box)
Corrections
Code explorer doesn't jump to top of the file if you expand/collapse main node
#2 Re: PSPad unicode 4.5.3 (2277) English
Posted by: hankejh | Date: 09/23/2007 19:01 | IP: IP Logged
Thanks for this build, Jan - the [Window > Horizontal Split] bug mentioned here:forum.pspad.com is gone!
Damion Hankejh / LinkedIn / ActiveCause
#3 Re: PSPad unicode 4.5.3 (2277) English
Posted by: pspad | Date: 09/23/2007 19:31 | IP: IP Logged
hankejh:
I promise to correct it.
#4 Re: PSPad unicode 4.5.3 (2277) English
Posted by: Ilya | Date: 09/24/2007 07:51 | IP: IP Logged
Thank you for the fast correction.
Ilya
#5 Re: PSPad unicode 4.5.3 (2277) English
Posted by: MrSpock | Date: 09/24/2007 10:11 | IP: IP Logged
Great! The problem with the smart file switching feature that I reported for the last build is fixed. smiling smiley
I think the caption of the new drop-down menu isn't in the language ini file yet ("Prepínání zálozek").
#6 Re: PSPad unicode 4.5.3 (2277) English
Posted by: pspad | Date: 09/24/2007 10:25 | IP: IP Logged
MrSpock:
You are right. Sorry sad smiley
#7 Re: PSPad unicode 4.5.3 (2277) English
Posted by: tobias1985 | Date: 09/24/2007 10:59 | IP: IP Logged
Thank you for this build.
Yes the entries in the scripts-menu are not in the language-files. Only this one is in the language-file: mScriptsRecompile_Caption=Recompile scripts
Make a final release soon. Actually it seems that pspad-project is dead. (last build on page is from 20. october 2006) I know some people who changed their text-editor to another one cause of some bugs. (which are already fixed in beta-versions, but most users don't know that)
So you lose some users and this is not very good.
Last, I think you need a collapse/expand-function in pspad (for functions, classes etc.). With this, you make much users happy and you reach a new user-group.
Thus you would stand out against other text editors.
Sorry for my bad english. I hope you understand me. winking smiley
Edited 1 time(s). Last edit at 09/24/2007 11:01 by tobias1985.
#8 Re: PSPad unicode 4.5.3 (2277) English
Posted by: pspad | Date: 09/24/2007 11:40 | IP: IP Logged
You are right. The Scripts menu isn't in the localization.
Reason? Menu is created by sripts. Name of the menu item depends of the script author. It can't be in the localization file.
#9 Re: PSPad unicode 4.5.3 (2277) English
Posted by: tobias1985 | Date: 09/24/2007 14:03 | IP: IP Logged
OK, but I have a standard-installation and no scripts added. So I thought the standard-entries must be in the language-files.
#10 Re: PSPad unicode 4.5.3 (2277) English
Posted by: pspad | Date: 09/24/2007 14:35 | IP: IP Logged
Standard entry is "Recompile script" only.
Editor PSPad - freeware editor, © 2001 - 2010 Jan Fiala
