You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.3 (2269) English
Posted by: tyzio | Date: 2007-08-06 06:51 | IP: IP Logged
Jan,
Any news regarding this issue? Compiler output shows all characters on a line printed over each other forum.pspad.com I used 4.5.3 (b2269) and the problem with log window is still visible. I found that when I change PC to faster one, each compile output with more than 10 lines is not readable. Right know I used Pentium D 2.4Ghz, previously Pentium 4 2GHz. Maybe something connected with refreshing rate?
Regards,
/TT
Posted by: simbabque | Date: 2007-08-07 08:31 | IP: IP Logged
tyzio:Jan,Any news regarding this issue? Compiler output shows all characters on a line printed over each other forum.pspad.com I used 4.5.3 (b2269) and the problem with log window is still visible. I found that when I change PC to faster one, each compile output with more than 10 lines is not readable. Right know I used Pentium D 2.4Ghz, previously Pentium 4 2GHz. Maybe something connected with refreshing rate?
Regards,
/TT
I had the same problem sometimes. I think it was connected with the number of lines. I used to compile my code several times with a lot of output and sometimes it just started to print everything over each other. Restarting pspad reset this, but it still kept happening sometimes but infrequently. I have not seen it lately, though.
Posted by: Luc | Date: 2009-04-08 15:09 | IP: IP Logged
- I just saw Lilypond was mis-spelled as Lilipod!
- I very much appreciate the hiliting of block comments with %{ ... %} - now is there a possibility to select some text and press a key combination to get this commented?
thanks!
