You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.3 (2269) English
Posted by: pspad | Date: 2007-07-16 16:35 | IP: IP Logged
Download links:
pspad.cincura.net (1.7 MB)
Changes to 4.5.3 (2265)
News
FullScreen function (F11) - menu View
Code explorer - new file type ftChrome
completion of the ` quote
FTP client - copy file name option in the context menu
SpellCheck - changed storrage for User dictionary files. Now are files stored in the .\PSPad\Spell folder and it's location depends of the Program settings \ System \ [x]Multiuser environment
Drag/Drop file into XHTML - you can switch odd the CLASS attribute in the Program settings / Direct edit
User highlighter - added multiline comment style %{ ... %} for Lilipod
Corrections
Perl highlighter - added missing UNTIL keyword
Code explorer for SQL - underscore in the identifiers
Code explorer for SQL - unique indexes
Program settings / Internet - proxy field was limited up to 4 chars
Code explorer - optimized INF file parsing
CLips - system vaiables has higher priority then uer variables
HEX editor - reopen deleted file causes exception
external text file change detection with active HEX editor doesn't actualize HEX editor content
Posted by: Stefan | Date: 2007-07-16 18:41 | IP: IP Logged
Thank you Jan.
Question:
Is this OK?
I see nothing about XHTML in "Direct edit" mentioned?
Jan:Drag/Drop file into XHTML
1) I have downloaded: PSPad unicode 4.5.3 (2269) _16.07.2007
2) Unpack in a new folder.
3) Started PSPad two times.
4) Looked into "Direct edit"
But i see nothing about XHTML there mentioned?
I see only this:
Quote:[Special settings]
LeftToPreviousLine=0
ContinueComment=1
OpenAllReadOnly=0
DontChangeFileAttribs=0
AutoDetectBinary=1
DragImgAlt=1
DragImgTitle=1
DragImgBorder=1
DragImgClass=1
TextClipsIfHLOff=0
CheckDocChanges=1
CtrScrollIfSelected=0
GutterClickInclLF=0
ExtraLineSpacing=1
OldMainIcon=0
HLOnUpToSize=500000
MultiHLOnUpToSize=200000
MaxRecentFiles=45
MaxRecentHistory=15
MainFileInPreview=0
F1HelpInEditor=1
ShowHint=1
Posted by: mathiasm | Date: 2007-07-17 13:41 | IP: IP Logged
What do you plan about customizing toolbar?
You started splitting the toolbar, and stopped there. I know some bugs need to be fixed, but this feature, once basically implemented, will allow for a stable release of 4.5.3. Don't you think ?
Posted by: mozdev | Date: 2007-07-17 17:49 | IP: IP Logged
Hi, Jan ;)
Incorrectly work parsing with chrome:// (gecko core browsers) protocol.
Can you update css file parsing that it work with http:// protocol?
It VERY important for me!
Templates your can see here.
Greeting from Russia ;) Thanks!
Posted by: pspad | Date: 2007-07-17 18:04 | IP: IP Logged
mozdev:Incorrectly work parsing with chrome:// (gecko core browsers) protocol.
I need examples, explanation what' wrong
mozdev:Can you update css file parsing that it work with http:// protocol?
What is wrong?
Posted by: mozdev | Date: 2007-07-17 18:17 | IP: IP Logged
pspad:I need examples, explanation what' wrong
#good {
list-style-image: url("http://foo.jpg");
#wrong {
list-style-image: url("chrome://foo.jpg");
and after formating
#good {
#wrong {
list-style-image: url("chrome: //foo.jpg");
Posted by: pspad | Date: 2007-07-17 18:43 | IP: IP Logged
mozdev:and after formating
#wrong {
}[/code]
OK. Important information for me was "after reformating" Corrected, wait for the next build, I hope next week.
Posted by: MrSpock | Date: 2007-07-18 14:22 | IP: IP Logged
The new Search/Replace settings (clipboard/selected text) are in the HTML tool section of the settings. Is this intended?
Posted by: pspad | Date: 2007-07-18 18:15 | IP: IP Logged
You can copy to clipboard text you want to use as replace text and call dialog. The you have prefilled both fields...
Posted by: mozdev | Date: 2007-07-19 04:25 | IP: IP Logged
pspad:OK. Important information for me was "after reformating"
Thanks ;)
