You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.3 (2265) English
Posted by: Lolo | Date: 2007-05-25 08:39 | IP: IP Logged
Hello Jan,
It seems that PSPad TextDiff from Windows contextual menu is broken.
Here is the way to reproduce it:
- Open a file into PSPad (PSPad have to be opened to reproduce the bug)
- Now select two files from windows explorer, right click on a file and then choose PSPad / PSPad TextDiff
- PSPad open a Open dialog box and does not compare files.
I hope you could fix this bug in the next release.
Posted by: pspad | Date: 2007-05-25 08:51 | IP: IP Logged
I know it already. Yes, it will be fixed in the next build
Posted by: ellocco | Date: 2007-05-29 10:30 | IP: IP Logged
ellocco:Hello,it's me again, the click on the "open-log-file-button"
is not allway successful, I found another trick to
enable the "compile button" again, the command
"change the main code file for the compiler"
works better.Kindest regards,
Stefan
Hello Jan,
from my point of view the disabeling of the
"compile button" is realy an important issue.
At the moment I work with "Crimson Editor" and
PSPad in parallel, if the "compile button" in PSPad
is disabled again, I switch to "Crimson Editor" .
A question:
Is there hope, that you introduce more column rulers?
At least two would be fine for fortran coders,
one left ruler and one right ruler.
A remark:
And than there are some fortran statements, that
PSPad don't know, if you are interested I will
check the fortran77 statements more systematic
and send you the result, e.g. DBLE, INT, ABS, DEXP
are not covered by the highlighting
Kindest regards,
Stefan
Posted by: Replika | Date: 2007-05-31 02:32 | IP: IP Logged
I replace my file with a regular expression
\\n ([a-zA-z]{2,})
\\n$1
But PSPad always replace it to real "end of line", not "\n"
ex
Quote:aaa\n bbb
becomes
Quote:aaa
bbb
please help...
Posted by: Fred | Date: 2007-05-31 04:52 | IP: IP Logged
You mean "aaa\n bbb" would become "aaa\nbbb" ?
If so you could try:
Find: (\\n) ([a-zA-z]{2,})
Replace: $1$2
Posted by: Replika | Date: 2007-05-31 09:22 | IP: IP Logged
Fred:You mean "aaa\n bbb" would become "aaa\nbbb" ?If so you could try:
Replace: $1$2
Thanks, but it should be fixed?
Posted by: pspad | Date: 2007-06-05 20:04 | IP: IP Logged
Replika:Fred:You mean "aaa\n bbb" would become "aaa\nbbb" ?If so you could try:
Replace: $1$2Thanks, but it should be fixed?
\n means replace with the line end. If you use regular expressions, you need to escape system chars.
Posted by: Replika | Date: 2007-06-06 04:36 | IP: IP Logged
pspad:\n means replace with the line end. If you use regular expressions, you need to escape system chars.
I did, you see:
Search:
\\n ([a-zA-z]{2,})
Replace:
\\n$1
But it does not work
Posted by: denight | Date: 2007-06-11 05:45 | IP: IP Logged
Exception address: 0
Stack list, generated 6/11/2007 1:43:27 PM
Thanks for the report,
but please do not post such lists to the forum,
rather send it to Jan by mail (see Help > About)
Thank you.
Спасибо за доклад,
но, пожалуйста, не пишите такие списки на форум,
а отправить его в Янв по почте (см. Справка> О программе)
Спасибо.
Díky za zprávu,
ale prosím neposílejte takové seznamy na fóru,
spíše zaslat jej na Jana poštou (viz Nápověda> O aplikaci)
Děkuju.
Program : D:\Program Files\pspad452en\PSPad.exe 4.5.3 (2265)
System : Windows XP Professional, Version: 5.1, Build: A28, "Service Pack 2"
Processor: Intel, Intel(R) Pentium(R) M processor 1600MHz, 1600 MHz MMX
Display : 1024x768 pixels, 32 bpp
Active Controls Hierarchy:
TPSSynEdit ""
"_1"
Edited 1 time(s). Last edit at 2014-07-14 18:19 by Stefan.
Posted by: Lolo | Date: 2007-06-11 07:45 | IP: IP Logged
Hello denight,
If you want to help Jan, you could tell him what have you done to have this crash?
