You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.3 (2265) English
Goto Page: 1 2 3 4 5 Next
#1 PSPad unicode 4.5.3 (2265) English
Posted by: pspad | Date: 2007-05-13 16:49 | IP: IP Logged
Download links:
pspad.cincura.net (1.7 MB)
pspad.siliconhill.cz (1.7 MB)
Changes to 4.5.3 (2262)
News
Ctrl+Click on the left gutter add/removes bookmark
Autocompletion - up/down arrows cycles in list
Parts of the splitted window are resized when whole window size is changed
New File Tab context menu item - Text Diff with active tab
New Code explorer file type for GameMonkey (ftGM)
Corrections
WordWrap with right edge mark was limited to 256. There is a problem with cursor for higher values yet.
Code templates - '*' in description adds item into CLip ShortCuts
Light line in the left gutter
TiDy check - summary was marked with the red point (error)
Scripting support - getVarValue() doesn't work with all variables from User variables dialog
File type change in Save dialog
FileTabs hidding problem in multiline mode
SpellCheck dialog - Autocorrection list modification wasn't active immediatelly
Variable evaluation problem (%Date%, %UserName%, ...)
Note
I am sorry, I was very hurry. Now I am working on long list of requests. Be patient please. Next builds will be available soon.
#2 Re: PSPad unicode 4.5.3 (2265) English
Posted by: holger | Date: 2007-05-13 21:46 | IP: IP Logged
Is there a chance for correction of highlightning for Multiline-Comments in next Version?
(Bold is highlighted)
Examble:
decription
Function
#3 Re: PSPad unicode 4.5.3 (2265) English
Posted by: denight | Date: 2007-05-14 04:10 | IP: IP Logged
Glad to see the new 4.5.3 (2265) version.
so when will the version 4.5.5 be released?tongue sticking out smiley
#4 Re: PSPad unicode 4.5.3 (2265) English
Posted by: pspad | Date: 2007-05-14 04:48 | IP: IP Logged
Multilevel highlighters depends of highlighter, not of program. It measn is necessary to modify individual highlighters.
General highlighter is very simple = it is hard to modify it.
#5 PSPad unicode 4.5.3 (2265) English - Important Keys do NOT work
Posted by: hoppfrosch | Date: 2007-05-14 06:02 | IP: IP Logged
just tested the 2265-build of PsPad. It shows the same behaviour as the 2262-build on my machine (WinXPSP2):
Some vital keys do not show any effect in these builds
(for example: Backspace, Delete, Return, Cursor-Keys ...)
PsPad simply ignores those keypresses and does NOTHING.
Using previous build 2261 everything works fine ...
#6 Re: PSPad unicode 4.5.3 (2265) English - Important Keys do NOT work
Posted by: pspad | Date: 2007-05-14 06:23 | IP: IP Logged
hoppfrosch:
Delete Keymap.ini file or in the program settings / KeyMap press "default" button
#7 Re: PSPad unicode 4.5.3 (2265) English
Posted by: holger | Date: 2007-05-14 06:30 | IP: IP Logged
Hi Jan,
for Highlighter I'm using a Individual one for Progress surely this should be language specific. But, as I guess, there's no way to handle it.sad smiley
There's another thing:
Code-Explorer works fine, but a '-' in the procedures name
makes PSPad cutting the name. Is there a hint? (Should be also individual for language...)
Examble:
PROCEDURE adm-open-query-cases :
Is shown as simple 'adm'.
Edited 1 time(s). Last edit at 2007-05-14 06:51 by holger.
#8 Re: PSPad unicode 4.5.3 (2265) English
Posted by: pspad | Date: 2007-05-14 07:23 | IP: IP Logged
Code explorer arsers are (and have to be) individual for each language. Language you talk about?
#9 Re: PSPad unicode 4.5.3 (2265) English
Posted by: holger | Date: 2007-05-14 07:47 | IP: IP Logged
About Progress (now Openedge) its a Sql-based 4GL Language for relational Databases (and Object oriented)
#10 Re: PSPad unicode 4.5.3 (2265) English
Posted by: MrSpock | Date: 2007-05-14 09:18 | IP: IP Logged
@Holger: Have you added the - char in Settings -> User highlighter -> Allowed chars in keywords:?
[German: Einstellungen -> Eigene Highlighter -> Erkenne Zeichen als Keyword-Teil: -_]
