You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.3 (2261) English
Goto Page: Previous1 2 3 Next
#11 Re: PSPad unicode 4.5.3 (2261) English
Posted by: fetis | Date: 2007-03-13 10:18 | IP: IP Logged
Thanks for build
#12 Re: PSPad unicode 4.5.3 (2261) English
Posted by: divopsp | Date: 2007-03-13 10:37 | IP: IP Logged
divopsp:
Little bug.
Find function: regardless if add line numbers is checked or not, List command adds anyway line numbers.
Verified with this release (2261) and previous versions
Bye
Ivo
This works for COPY button, not for list button
ok, sorry. I wonder if you could add this useful switch to the List command too; it's possible?
thank you in advance
Ivo
#13 Re: PSPad unicode 4.5.3 (2261) English
Posted by: Firefox | Date: 2007-03-13 12:41 | IP: IP Logged
Hi.
It seems, that lighlighting of Perl source code doesn't work correctly. Following command breaks it:
$abc=~s/\&quot\;/\""/g;
#14 Re: PSPad unicode 4.5.3 (2261) English
Posted by: Mahir | Date: 2007-03-13 15:13 | IP: IP Logged
afaik, this is a problem which is related with synedit edit component.
if you add #" at the end of the faulty line then the syntax below will shown correctly.
regards,
Mahir
#15 Re: PSPad unicode 4.5.3 (2261) English
Posted by: Eblis | Date: 2007-03-17 21:00 | IP: IP Logged
Sorry for pushing this but i'd really love to see this feature added to PsPad (first post)
#16 Re: PSPad unicode 4.5.3 (2261) English
Posted by: pspad | Date: 2007-03-18 06:43 | IP: IP Logged
Eblis:
Write interactive clips for your purposes. Try HTML file and clips e.g. for TABLE
#17 Re: PSPad unicode 4.5.3 (2261) English
Posted by: pspad | Date: 2007-03-18 12:41 | IP: IP Logged
divopsp:
divopsp:
Little bug.
Bye
Ivo
Ivo
Reason?
#18 Re: PSPad unicode 4.5.3 (2261) English
Posted by: Eblis | Date: 2007-03-19 10:45 | IP: IP Logged
Eblis:
I did try interactive clips but i find them a bit intrusive for some tasks.
#19 Re: PSPad unicode 4.5.3 (2261) English
Posted by: divopsp | Date: 2007-03-19 10:59 | IP: IP Logged
reply @#17
because i find useful this switch anyway.
when i use List function, most of the times i don't need line information.
i use it as a "like" filter from a file
but it's only my opinion, and i can anyway delete the line indication from result
sorry for my mistake
ciao
Ivo
#20 Re: PSPad unicode 4.5.3 (2261) English
Posted by: pspad | Date: 2007-03-19 12:54 | IP: IP Logged
divopsp:
reply @#17
ciao
Ivo
I can't explain, ho it should work, if function contains several parameters.
Dis you look at interactive clips?
I ting it's more useable then your idea
