You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.3 (2259) English
Posted by: toralf | Date: 2007-03-08 12:16 | IP: IP Logged
Thanks for the Code explorer for AutoHotkey.
Unfortunately I found an issues in the latest release.
In the AutoHotkey language a block comment is between /* and */. Thus, the following is a Label with a Comment:
Label:
XYZ: Text
blah blah
Unfortunately PSPad shows the "XYZ" as a label in the Code explorer for AutoHotkey. Is there a way to avoid this?
Posted by: pspad | Date: 2007-03-08 15:55 | IP: IP Logged
I don't know Autohotkey and nobody tell me abut comments.
I added block comment style into code parses. Ceck next build
Posted by: Progress coder | Date: 2007-03-08 20:28 | IP: IP Logged
pspad:Progress coder:Hi Jan,
Thanks for your really GREAT editor.
Now using it 2 months, and enjoying it!I want to report a bug in the Beta:
Smart Tabs doesn't work anymore. The line, where you enter TAB, is started on the first position, and not on the TAB position from the previous line. You see this also when entering TAB on existing line with code. The code is then shifted to the first position of the line. (it seems the TAB triggers 3 actions, see this if you UNDO the TAB).Disable []Trim trailing spaces in the Program settings
This option was not enabled and does not have any influence.
Problem remains that when the cursor is at position 1 at the left margin AND when I press TAB the cursor does not move (it does not matter if the previous line is empty or not). And if the cursor is not at position 1 TAB does move the cursor AND existing code to position 1.
Changing TAB width (4) or Indent width does not solve the problem.
I've reinstalled version 4.5.2, but there the problem also occurs.
I am convinced the TAB worked differently before, but I can not re-produce it.
Posted by: toralf | Date: 2007-03-09 11:09 | IP: IP Logged
pspad:I don't know Autohotkey and nobody tell me abut comments.
Thanks a lot. Very much appreciated.
Posted by: grouk | Date: 2007-03-09 12:32 | IP: IP Logged
These are a bug in log and autorefresh windows:
The characters, in the log or an autorefresh window, may become Chinese when executing an external compiler.
For example, this very simple python program, launched with "python %File%", returns in the log, after 1 to 10 calls:
This bug appears also with other compilers (I have try cmd, gcc, python and personal programs). It also appears if the compiler modifies a file opened with an autorefresh window.
My config :
Windows XP SP2, processor: Intel(R) Pentium(R) 4 CPU 2.80GHz, 1023MB RAM.
Regards,
Grouk
Posted by: Progress coder | Date: 2007-03-13 20:36 | IP: IP Logged
Aaahh, I found the cause of not indenting.
I had installed the scripts of CIndent (as example), and there is a key mapping to TAB.
I am sorry to have bothered the forum.
Posted by: Frans Koning | Date: 2007-03-15 08:31 | IP: IP Logged
Is there any view yet on when we can expect SFTP (FTP over SSH2) support? When this feature is in, i might aswell throw jEdit overboard and start with PSPad...
