You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.3 (2259) English
Posted by: Lolo | Date: 2007-03-05 09:59 | IP: IP Logged
naputtelija:Word wrapping is broken in HTML commentsEasy to verify:
<html>
long enough line, add some more text and you will see
</html>
I can confirm this behavior.
Posted by: igece | Date: 2007-03-05 10:07 | IP: IP Logged
Every time an existing file is opened, the active line is highlighted for this file, no matter if 'View->Active line' is deactivated. It is necessary to check two times this option to disable active line hightlight for this file.
Posted by: pspad | Date: 2007-03-05 10:42 | IP: IP Logged
<html>
</html>
I don't see any "broken" problem. Can you send me screenshot with description what is wrong?
Posted by: Lolo | Date: 2007-03-05 12:27 | IP: IP Logged
You can find example here :
Without Word Warp
img92.imageshack.us
With Word Warp
img138.imageshack.us
Otherwise, you can do it yourself with this piece of text:
<html>
long enough line, add some more text and you will see abcdefghijklmnopqrstuv 0123456789 Now, you can see the problem
</html>
Posted by: Jody | Date: 2007-03-06 04:30 | IP: IP Logged
This was exactly what I was talking about when I accidentally posted in the main developer thread (sorry about that-- wish you could move or delete).
This behavior occurs in plain txt files as well.
I would send a screen shot but it looks the same as Lolo's and besides I've reverted back to 2255.
Jody
Posted by: Mahir | Date: 2007-03-06 05:28 | IP: IP Logged
This is a very annoying bug but it exists:
With word wrap on, long lines cannot be edited correctly.
Best regards,
Mahir
Posted by: MarkRH | Date: 2007-03-06 05:57 | IP: IP Logged
Yeah, with 2259, if I go to wordwrap mode and then just start typing within an existing HTML comment.. things start to go wacky with characters changing at the end of 2nd "line" of the word-wrapped line and characters appearing ahead of the cursor and changing around.
2255, no such problem. Have gone back to that executable for now.
Mark H.
Posted by: skwire | Date: 2007-03-06 07:13 | IP: IP Logged
The AutoHotkey code explorer issue from build 2255 appears to have been fixed. Thanks, Jan.
Posted by: Matt | Date: 2007-03-06 15:16 | IP: IP Logged
Thanks for the latest release. However there is still an issue with the tabs that occurs between switching desktops. I posted a screenshot to better illustrate what I am talking about:
It seems to be a function of how many tabs are open. If I have <= 2 tabs open, I don't see it. But the more that are opened, the more white space is generated below the tab.
Posted by: fonitzu | Date: 2007-03-06 20:24 | IP: IP Logged
I will reply until somebody tells me 'go home'
It's about the column selection bug
forum.pspad.com
