You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.3 (2247) English
Posted by: pspad | Date: 2006-11-21 19:24 | IP: IP Logged
Download link: pspad.cincura.net (1.7 MB)
Changes to 4.5.3 (2246)
News
new scripting suport - blockBeginX, blockBeginY, blokEndX, blokEndY - returns selected block bounds
new FTP connection parameter - cut off file extension
standard Windows dialog for set clors is back
Corrections
new file with template - upper case extension
HTML template highlight support
Posted by: Eblis | Date: 2006-11-21 20:28 | IP: IP Logged
Thanks for adding default color picker control back to Settings->Colors.
I'm also happy to report that the ruler now uses the same background color as the left gutter (not listed in the changelog). THANKS.
(ps, i noticed that you changed the way the right line is displayed in 2246 to dot-line-dot and in 2247 you changed it back to dot-dot-dot. )
Posted by: Christian | Date: 2006-11-21 20:59 | IP: IP Logged
There is a minor bug in the new Color Selector window using "Named colors": the display of the selected color's name is updated only on double click while the correct color itself and its hex code are shown immediately on single click.
BTW: Jan, would it be possible for you to include an additional control for "brightness" in the Color Translator window?
Posted by: Jeroen | Date: 2006-11-21 21:21 | IP: IP Logged
Since build 2246, every time I start PSPad, the width of the FTP-panel is reset, so that the buttons on top of the panel cover two rows. Before, my custom width was saved, so the buttons covered just one row. Could this be set back?
Posted by: Jeroen | Date: 2006-11-21 21:29 | IP: IP Logged
Eblis:(ps, i noticed that you changed the way the right line is displayed in 2246 to dot-line-dot and in 2247 you changed it back to dot-dot-dot. )
I noticed this too, however, when a new file is created (File -> New...) and it contains only a few lines, the gutter in the rest of the document's text area is a solid line instead of dotted. This is not good-looking:
Edited 1 time(s). Last edit at 2006-11-21 21:29 by Jeroen.
Posted by: Funbug | Date: 2006-11-21 22:00 | IP: IP Logged
Quote:standard Windows dialog for set clors is back
Hooray!
Posted by: lphilpot | Date: 2006-11-22 04:15 | IP: IP Logged
pspad:standard Windows dialog for set clors is back
Thank you!
Len Philpot <><
Posted by: Stealth | Date: 2006-11-22 14:45 | IP: IP Logged
Thank you for html template support!!
Posted by: Eblis | Date: 2006-11-24 08:36 | IP: IP Logged
Could you please enhance the user highlighter so it supports keyworks like [U14]Cannot. I think they don't currently work because it treats [U14] as a new Ini section :(
I also have another question about the user hightlighter. How can i add words likeINFO 0
(5 spaces between info and 0) and -start to the definition file ? I tried adding (space) and - to the list of KeyWordChars but it didn't seem to work.
Posted by: pspad | Date: 2006-11-24 08:49 | IP: IP Logged
Sorry, it isn't ossible without rewrite user highlighter handling - change format of the file.
Words contain spaces are not one keywords, but two.
