You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.2 (2238) English
Goto Page: Previous1 2 3 Next
#11 Re: PSPad unicode 4.5.2 (2238) English
Posted by: tyzio | Date: 2006-10-11 12:58 | IP: IP Logged
Thanks for this release, like always very good jobgrinning smiley
Anyway, I found something like these:
- Indent/Unident doesn't work for single line without any selection
- Check spelling: The underline disappers when user clicks on underlined word when wrap line is ON
In additional, it will be really helpful when:
- defined Tools have hotkeys
- 'numeric base translator' and 'expression evaluator' windows were made in the same form like 'color selector', 'clipboard monitor'.
Thanks.
#12 Re: PSPad unicode 4.5.2 (2238) English
Posted by: LucasDT | Date: 2006-10-11 13:49 | IP: IP Logged
There is a problem with drag and drop feature.
When you drag and drop a file into a previously open file, it copies the path and filename instead of open it in a new tab.
The drag and drop works ok when you drag de new file into the file tabs view.
This behaviour is different from the one of the previous release.
I don't now if it's a bug, or if it is intentional, but there should be a way to disable it (and if there already is a way, please, tell where it is, I can't find itsmiling smiley).
Thanks for all the excellent work you're doing.
LucasDT
#13 Re: PSPad unicode 4.5.2 (2238) English
Posted by: Wacky | Date: 2006-10-11 18:47 | IP: IP Logged
The Bug with the log window is still present. sad smiley
--> forum.pspad.com
#14 Re: PSPad unicode 4.5.2 (2238) English
Posted by: Yuval | Date: 2006-10-11 18:49 | IP: IP Logged
Tonda:
Thanks for the SendTo-Fix!
I'd pay attention for that remark pspad, since the changes list does not imply you tried to fix it.
I say this because of Lolo's problem with the files - IIRC, these problems influenced the way Send-to worked, so it seems that one man's solution became another man's problem...
I cannot comment more about this, as I'm not using PSPad in such a way to be affected by neither of these behaviours, but I'm just suggesting where you might look smiling smiley
#15 Re: PSPad unicode 4.5.2 (2238) English
Posted by: pypardo | Date: 2006-10-12 07:15 | IP: IP Logged
I'm not really sure that this problem exist only in release 2238 (in fact I'm sure it exists in some previous release).
In Project menu, my list of MRU project contains always 1 project, this list is never updated.
I try to open or create new project, but this list contains always the same old project.
Any idea ?
Best regards
winking smiley
pierre
#16 Re: PSPad unicode 4.5.2 (2238) English
Posted by: pspad | Date: 2006-10-12 08:00 | IP: IP Logged
pypardo:
Any idea ?
Best regards
winking smiley
Recent item is inserted into list when you close it.
PSPad store recent item in Recent.INI file. Check, if isn't read only.
#17 Re: PSPad unicode 4.5.2 (2238) English
Posted by: Lolo | Date: 2006-10-12 09:35 | IP: IP Logged
Hello Jan,
I have found a problem with column mode selection.
Here is the way to reproduce it:
- Open the file I sent you.
- Use Tab width to 30
- Select the middle column in order to delete it
- Delete the selection
You can see that a piece of last column has been cut.
(see screenshot in order to see what I mean)
More, if you hit Ctrl+z to cancel changes, the last column is not restored correctly
Otherwise, is there a way to keep the column selection mode activated?
I ask for this because as soon as you click anywhere with your mouse, the selection mode return to normal selection.
Thanks and have a nice day.
#18 Re: PSPad unicode 4.5.2 (2238) English
Posted by: pypardo | Date: 2006-10-12 09:44 | IP: IP Logged
I've already check this. My recent.ini was not readonly. And the only project that appears in my project list wasn't in this recent project list (in recent.ini).
but.... it's ok, i've fixed it
The project list was stored in the registry !
And it seems that one of the project has a name that locks the mru list.
After clearing my projzect list in registry, everything to be ok.
Best regardssmiling smiley
#19 Re: PSPad unicode 4.5.2 (2238) English
Posted by: Jon | Date: 2006-10-12 09:55 | IP: IP Logged
Next Window and Previous Window are broken.
Once I have given focus to the tool panel (ie edited a project) it is impossible to switch between open editor windows. Next Window and Previous Window only switch tabs in the tool panel.
Ctrl-Tab does works.
So I am back to 2237.
#20 Re: PSPad unicode 4.5.2 (2238) English
Posted by: Anonymous User | Date: 2006-10-12 10:00 | IP: IP Logged
Works perfectly for me, and I haven't changed anything since the previous build.
